Hi Guys,
It has been some time since I have been on the forums.
Some of you may remember that I was doing a rb25det conversion in my r32 gts-t.
It is now all complete.
Due to alot of delays such as waiting 2 weeks for a gtr speedo drive and waiting 3 weeks for an auto elec to do my wiring loom, I can now say I am not sorry as it was all worth it.
I used a s2 rb25 from a late 96 r33, along with the gearbox and wiring loom.
I added a 3" front pipe onto my apexi exhaust system, power fc and blitz spec r boost controller.
On dyno dynamics dyno it made 197.6kw's at the rears on 11.5psi.
The overall drivability of the car is sooo much better. It makes you feel that the rb25 should have come in the 32 from factory.
Take it Easy
Mark :cheers:
https://www.sau.com.au/forums/topic/71647-rb25-conversion-complete/
...The overall drivability of the car is sooo much better. It makes you feel that the rb25 should have come in the 32 from factory.
LOL..careful:)
Nah excellent to hear you are back on the road, and happy with the results. Do you mind me asking what it ended up setting you back, basically what you were expecting or more?...as im curious to know the real cost of such a swap, as i recall thinking based on my numbers it would cost more then you were thinking... Just curious to know if my numvbers were wrong/ im talking to the wrong ppl?
Now throw a 2530 on it and drive the wheels off it:)
Hi Roy,
No probs mate.
I purchased the motor, gearbox, loom and factory ecu for $2,500.
It should have been $3,500 although they took $1,000 off for the rb20.
For labour it ended up being just over $2,000 then plus $400 for tuning and $500 for the wiring loom.
I'd luv to get a 2530, 2535 or even a hi-flow although my wallet isnt very happy with me at the moment so it will have to come in the distant future :cheers:
take care
Mark
LOL..careful:)
great stuff mark :D I think you got a very good price for it all in the end, considering you have got an RB25 gearbox behind it, and somebody else did the labour also.
Better you have a smile on your face everytime you get in now.. that power level is impressive too.
I'm just sorting out some of the basics with mine and having some fun with the ol' rb20, but probably will be closer to end of this year/start of next before I get my motor in there. I'm interested to see how skylinegeoff's old "2530 equivelent" goes on my 2L first, then the 25
Hi Sydney Kid,
Yes I think the suspension may need a bit of attention.
At the moment I have Tein HA Coil Overs, although I think it would be nice to get those whiteline sway bars and front adjustable castor rods.
I did have a strut brace although I have to find a way to get it to fit now :)
The Teins are quite good though, as there is minimum body roll when cornering.
Take Care
Mark
Hi Sydney Kid,
I did have a strut brace although I have to find a way to get it to fit now :P
Take Care
Mark
Tein HA's, are yes, that explains it. Rediculously high spring rates, particularly in the rear. Hence a lack of compliance and the tyres skip from ridge to ridge in the road surface and the result is poor traction. My low cost suggestion is (as always), put the rear springs in the front and spend $150 and buy a set of rear springs with more suitable spring rates.
Stabilser bars are for controlling roll, not springs. Springs are for holding the car up and providing compliance for bumps. Horses for courses as they say.
Ohh sorry Roy if I offended you before about the rb20's :P
I don't hate rb20's.... I know they have feelings too.
That sounds cool Gordo :D Keep me posted on how your going...
Take it Easy
Mark
no they don't! :)
Mark - where'd you get the engine from? Cos that's a really decent price.
Hi Nathan,
I got my motor from Tyrone at De Silvia Parts in Clayton.
His No is 0417 338256.
If you talk to him tell him you know Mark with the white r32 and he'll look after you.
He's got quite a few rb25's :)
take care
Mark
:( unfortunately I'm in Sydney...but thanks for the contact Mark.
Quote: unfortunately I'm in Sydney...but thanks for the contact Mark /Quote
You can try powerplay imports, as a friend of mine did it thru them..
www.powerplayimports.com
Glad 2 hear another person has done this conversion with a huge smile on his face..
Good stuff Mark!!!
I knew I had you converted - I miss my old RB25 powered R32 - it felt so good in a light R32!!
I hope too many people dont do it, itll make it common - Back in Perth my car was the only 1 of 2 - RB25 powered 32s, and considering 32s were rare over there, it was even better. I only had to take someone once for a ride in that car to convince them, especially when they were hanging on for dear life when the car was wheelspinng 3rd sideways up the street :) Ahh the memories!
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
