Hi guys/girls, I'm new to this site. I found it when i was searching on the net by accident and i am very pleased to see that there is many people out there that share the same passion for skylines and I do.
Is there many people going to the auto salon on this weekend? Anyone going to have their car on display???
https://www.sau.com.au/forums/topic/71800-new-female-sau-member/
  • Replies 63
Hello
Here is the autosalon thread:
http://www.skylinesaustralia.com/forums/sh...ead.php?t=70984
There are 15 I believe. R31Nismoid and Adzmax would be the best ones to ask specifically about Autosalon I would say. Ash and Adz respectively.
LOL hrmm... where are all these new people coming from!? hehe, you dont have to mention you're a new female forum member... just 'new member' is fine :D
Annywayy Welcome to SAU Vic, yes we have a club display at Autosalon this weekend. Come and say hello, introduce yourself. Don't mind Ash if he's a bit drunk :D
Check out this thread too.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
