Fullboost pics are up (you have to register but it's free):
http://www.fullboost.com.au
From the site:
The Melbourne Auto Salon was held over the weekend at the Melbourne Exhibition Centre and is without doubt one of the biggest indoors shows of the year. The Dyno cell is always a popular spectacle with big power from all classes.
XTC Engine Management and Turbocharging (03 9354 1198) setup their 4WD dyno and for the second year running Ice Performance took outright honours. David Lee’s ‘RBDET’ GT-R Skyline ramped up 604kW at all four (reclaiming the 4WD record) on Saturday while in RWD mode also made 608kW struggling for traction. Nigel Beale’s bright orange ‘DAMN’ Supra wasn’t too far behind with a very strong 585kW reading. Benny Kashima’s Chasers Drift S13 punched out 333KW from it’s Nissan SR20 engine and tied for the 4-cylinder class.
The Autosalon series now moves to the Sydney Showground (May 14-15) and will be back in Melbourne for the semi final event (November 12-13).
  • Replies 132
I guess they lose the passion...they look alright to me though. I can't stand when "professional" photographers have blurry images!
Really nice photos from all the SAUers, looks like you're enjoying that camera Dark. Great work on the stand guys (and girls!), good to see Dave's GTR back on the dyno and reclaiming the AWD record.
haha, i dunno.
i guess im just pissed off about it, because the fullboost editor was meant to get back to me before autosalon started about being a photographer for them..
but im not sure what happened to our discussion...
i would've appreciated it if he even at least said no... but he didnt deny it, nor confirm it..
haha, yea, i love it.
i gotta save up $500 for the 50mm f/1.8 and the 55-200mm USM lens
i -really- want the canon 10-22, but that costs almost as much as the camera itself.. lol
any pics from you Greg?
Couple of things, my new speedlight didn't arrive on time (so I could take flash photos of shiny surfaces!) but also it was the Russian (and Greek and few others') Easter over the weekend so I had heaps of family commitments.
Really wanted to go though, just the timing was bad for me this year.
i need naaawwss!!! :(
when's the next one guys? September? f*ck if my car ain't ready by then i'm going to f*cking kill myself... or the car, one or the other. Looks like a great weekend, and i keep missing 'em ;)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
