Hi guys,
Just after peoples opinion who have tested Toyo T1 R's and Falken RT615's, what would your thoughts and feedback be on each compared to each other only. Dry/wet, overall. Im deciding between these two and need peoples experience to sway me to one over the other.
Thanks for your input.
Stan.
Hi guys,
Stan.
i have t1-rs myself and have ridden in 2 cars with 615s, you cant really compare the two, the 615 is designed way more agressive tyre, they will wear out quicker, be noisier, harsh ride, and biased towards dry girp whereas a t1r is a normal top of the range tyre which is quiet, softer sidewalls, better life etc.
so you shouldnt compare the two, but if you want a comparison i can tell you that the 615s dry grip is incredible when compared with the t1-r. the t1-rs are some of the best normal road tyres i have tried along with sport maxxs, but in terms of dry grip they are light years away from 615s.
a fairer comparison would be 615 vs toyo r1r but r1rs are not sold here anymore anyway...
Front: Falken ZIEX ZE326
Rear: Falken FK451
Absolute rubbish these tyres. Just can't put power down through them, they don't handle corners.
Grip about the same both wet and dry, I can't say if they're worth buying, as I don't know what they're worth to buy, but they're basically brand new on the car at the moment.
I wouldn't even tell my enemy to put them on there car!
well,
My dunlop 3000A's have finaly gone to shit! I have yoko C drives on the front - was reccomended to them, but I feel there is room for improvement...
I heard the yoko a v s's are good - anyone know?
Brendan - would they have those tyres in the smaller 225/50/16?Federal SS595's that is!
Im not brendan.haha.i dont know if they do but you can allways try.ive also heard good things about the falken fk452's as a budjet sports tyre.duncan raves about them.
lol I do, and stand by the recommendation :P
I just put federal 595 on the front of the 350z after all the good reviews. I would say:
Dry : 7/10
Wet : ?/10
Value for $ : 9/10
Performance wise these are very good road tyres, not as good as the dunlop sp9000 but still in the top few I have used. Not sure about wet yet but am not too hopeful.
But they are harsh and noisy for normal drivnig, kind of like a semi slick (but not as bad thank god).
Still at the price I think they are a good choice if you don't mind the noise.
I paid 220ea in 245/45/18 from Payless Chatswood.
Just spoke with chatswood payless for tyres - they dont have the 595's in but havwe the 535's - they say they are almost as good, not as noisey and hold up pretty good. anyone know for sure?
seem a good price
Has anyone here tried the Toyo R888 in the different compounds? I woud like to know what differences there is between the SG and the GGG compound. I know SG is softer but how much difference does it really make?
RE01's.. came with car, seem to work good :rofl:
Same here. havent got any wet driving experience yet (only had the car 4 days) but i can report that in the dry these hold on beautifully considering they have aged a bit and have gone hard from sitting around the docks and compliance workshop. would have loved to try these new
Michelin Pilot Preceda PP2 , these are the fruit on road IMO . Car is R33 GTS25T with SK/Whitline full suspension kit . Wheels are Rays Engineering LM1GT4 5 spoke 17 x 8 30P and tyres 235/45/17 profile .
In the dry it would take stupid speeds to find the limits of adhesion and since its public roads ATM not going to find them . Damage was 235 each so 940 the set .
Cheers Adrian .
hey have a 95 r33 gtst with only a few mods like 3 inch exhaust, turbotech boost controller set at 9psi, and possibly a aftermarket ecu. just bought the car and has new nexen n2000 225/50 16 tyres and i must say they are no good at all. very easy to spin tyres dosent grip around corners and even worse in the wet. want to replace them soon. what would be a decent fairly cheap tyre that would hold better than these and aprrox cost of them.
Chris_S15-- I have advan Ado7s in 255s in the rear..
I must say they have excellent grip in the dry when its warmed up a little..
I would recommened them, but its so expensive to buy a new set at around 400 each..
Lucky my rims came with them..
But go for it if you have the money!! Trust me!!
TRUST33-- pretty sure they are.. The sports are top of range..
Edited by siddr20
Will I feel much difference between sport maxx and sp 9000 on the road(no track work) as a whole in all conditions as a total package? Giving for same price so not too sure what to do?
I've not tried the sport maxx.....but you will not be disappointed witht he sp9000 - they are the best road tyres I have used (and I get through a heap of them)
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
