awesome day, ran a personal best, thanks to Steve and Dave from Haak Automotive for setting up the car and staying up late to tune it. Go the 2J powered COROLLA i cant believe it went 9.4@158mph with no trans brake shiiiitt!!
Previously ran 11.6@124mph with a Unique autosports tune making 326rwkw
Ended up going out there with a SAFE 322rwkw and ran 11.1@119mph
Unfortunatly im having problems with the pump that john put in. Its seems to surge and thats why of the 4 passes i couldnt complete two.
two06l sounds like a animal going up the stretch, i cant belive a cat had to ruin half the day for you guys.
i have some pics but i dont know how to put them on, i think there to big :confused:
  • Replies 152
Are you guys all aware of our drag day on 31 July?
Check my signature.
no im not, i will definately pass the message on to the guys at haak automotive. There are some wicked cars there, will the cars like the corolla be able to run?
im not sure whether ill be able to run then, im going to convert to a single turbo soon so fingers crossed ill have something ready
Steve will your car be finished?
Abo Bob I am well aware of the SAU drag day and will be there if car is all ready which it should be. I am not one to say I will do something then not turn up unless real and very good reason. Will let you know.
car looked very nice mate. :cheers:
good work on the PB, so very close to a 10. 11.1 is pretty tough for a street car with just steel wheel turbos.
what type of torque split controller are you using for the burnouts?
G[/img]
I spoke you got a couple of minutes for you lined up for a run . Thats certainly a good result you got .I've got probably a tiny bit less power then you going out to the drags again soon would be happy with something close to 11.5 let alone an 11.1 .
Got a few questions for you what kind of boost are you running on these steel wheel turbo's it's certainly a good power figure and are you still running on standered internals? . What tyres on the rear you running ??.
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
