  • Replies 172
On a day of crazy fast times and cars your effort was execptional Brisby. Well done.
I still can't believe I ran a 1.22.2 and that it was only good enough for the 7th fastest time of the day. That's a seriously quick group of cars out there.
But anyways I'm exhausted and I need to go find a beer.
Well what can I say, a day full of excitement and dissapointment, it just wasn't my day... After 5 attempts the intercooler piping was just not holding full boost in fourth gear, resulting in 1 complete timed lap of 1:29.... I wanted to leave at the end of the day with a sub 1:30, so I guess that's something to be proud of...
Full congrats to Roy, stepped up to the challenge and delivered the goods... WELL DONE TROY!!!! Hopefully next outing at Sandown I'll be able to match the time....
Gareth (Rowdy R32), brings a tear to the eye seeing your car after the crash, you walked away unscathed so I guess that's all that matters.....
Snowy, good to see you improved on your previous time...
I must give out a big thank you to Andrew (ferni) and Denton (DentonR33??) for their help in trying to sort out the intercooler piping issue, Cheers guys, really appreciate it!!!
And to all the rest of the SAU clan, good to see you all out there supporting us TEAM WANGERS!!!!
Looking forward to the next one!!!
how'd the new brake setup go?
Great to see the team going so well. Was nice to drop in and say hi. Great time Troy, and I trust the car made it through the day unscathed. Is this a new watershed? 58Y finished a track day?
Gareth, condolences on the wall incident, but consider the fun of rebuilding :)
So what were the critical lap times?
Did Benno stave off the assault from that nice white GTR32?
As far as I know:
Me - 1:29 (1 timed lap for the whole day, retired early)
INASNT - 1:33
Roy -1:25
Snowy - 1:22
wwwrrxxx - 1:22
Frank - 1:20 (retired early)
RPMGTR - 1:17
Correct me if I'm wrong....
Not sure of Ant95GTR and any other TEAM WANGERS.....
Chris pulled a 1.23 before the gearbox lunched itself.  I would have put bucks on 22s.
I think it is time to change my user name..
Took me about 10 minutes to get used to my clutch again Jack..
Oh yeah, forgot all about Chris!!! Aaron, very impressive time considering you have bugger all mods on your car, must be the driver!!!!
Yeah clutch is a bit aggressive, good for holding the power though.....
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
