Hi as it says i have R32 GTSt interior including, seats (front and rear), door trims and rear trims. Only selling coz i bought the GTR equivelant of all and converted.
Interior items are as follows, all from R32 GTSt:
*front seats, on rails (small tear on drivers side) - $300pr SOLD
*rear seat (immaculate) - $150ono
*rear trims (the bits that are either end of the back seat, with the arm rest) - $150ono SOLD
*Front door trims - $150
Will sell whole lot for $600, you pay delivery.
ONLY REAR SEAT AND DOOR TRIMS LEFT
Head sold.
Cheers
G
Edited by geordie
https://www.sau.com.au/forums/topic/73804-r32-gtst-interior-rb25-head-pics/
RB25 head, cams, and cam gears included - $400
Rb25 intake plenum, trottle body, injector wiring loom - $250
Rb25 Injector rail + stock regulator and stock injectors - $150ono
Package price for the above please, and can you organise delivery or would you prefer me to.
$650 plus what ever delivery will be, i suspect it may be to heavy for good old aus post, but yeah i will check out some prices for you if you like. Prolly through pack and send or someone similar.
Cheers
G
what condition are the door trims in?
how much will you do the entire rb25 set up for?
thanks
Same price i gave funkymonkey for rb25 stuff.
As for the door trims, they are good...BUT! the cloth part has come away on the drivers side. They also have tweeters glued to them down near the grill, as you will see in the pics) if you want pics, pm your email addy.
Cheers
G
Hey where abouts in melbourne r u? Do u still have the inside air conditioner air vents if so how much will u sell them for becos i need 2 put them in my car so it can pass a road worthy can u please call me on 0413442008 catherine after 4.40pm thanks
You havent read my post at all have you? Or my location? Its ok i wont hold it against you. Best bet if your chasing vents is to go to nissan direct. The r32 GTR was sold in australia so they can stil source parts. I last heard vents are around the 30-40 mark.
Cheers
G
geordie, price sounds good depending on freight costs, worst case scenario I'll drive up and pick it up or something with a deposit.
Can I get some high res pics of the parts I'm interested in sent to [email protected]
Cheers
Cheers
Head, plenum and injector rail are about the 50kg mark all up. So definately to much for aussie post. Even split into multiple boxes the head its self is about 25kg.
Cheers
G
hey do you have the power window switch from the drivers side door?  If so wat condition and how much?
Nope only the door trim. No switches, no handles, or vents. Just door trim, rear arm rest trim, seats. These are the only difference betwen the gtr interior and the GTS..
Cheers
G
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
