lol @ the prelude wheels
btw the gearbox alone is worth more than my whole car lol
What type of box is he going to be running?
Is he going airshifted (gforce) or other? I'm guessing other by the number of levers in there :whatsthat
  • 1 year later...
yea i know this thread is old but i thought i would post some updated pics thanks to TRP
http://www.rigoliracing.com.au/r32_gtr_dragcar.html
Vehicle: 1993 R32 GTR
Power:
Best E.T:
Engine: RB30 with RB26 head
Induction: 2x Innovative T66 turbos
Internals: TRP Spec
Ignition: Microtech x6
Exhaust: Twin 3"
Engine Management: Microtech LT-12
Boost Control: Turbosmart eBoost 2
Drivetrain:
Clutch:
Gearbox: Lenco CS3 5 speed
Diff: 9"
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
