In my opinion the sump plug method will be easier. Sure it's messy but isn't it easier than getting to the filter, again, and again, and again?
Personal preference. But the drain bucket under the sump, strap on a kitchen glove, and off you go.
Yeah it will take ages to drain 4Ltr's from the oil filter, Get ready for a messy job :P
just drain from the sump plug into a CLEAN container. Then refill, check it carefully on the dipstick as you do :P
BTW 2cm over the top of the dipstick is not terrible AFAIK. I'm not sure but the crank may not even be hitting the oil I think. Maybe someone has a bottom end apart and could confirm?
yeh hey all, thanx 4 ur replys
i took the extra oil out.....via sump plug...was a bitta fun havin a play under there even tho it was cause i did something dumb it first place but ah well.
Also guys.. is Castrol Formula R Synthetic 0w-40 ok to use in my gtr?
thanx
ive already put the formula r synthetic 0w-40 in so is it cool,. or should i take it out.....i live in tassie so it gets really cold here in mornings etc so i thought the 0w would be good and the engine is in fairly good nic touch wood so 0-40 should be ok yeh or too thin ?
hehe my mate a couple of years ago did that, his dad told him to go down to the servo to top up with a bit of oil cause it was low,so he did when he got back he say's to his old man it took ages to fill up i went though 3 bottles and its still not full, well he was never aloud to do anything for his old man again :):)
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
