guys
I had a set of non-turbulence (HKS style) dumps made up by custom exhaust here in Brisbane, used mild steel and had them HPC coated - and they work great (20+AWKW extra)
Already had custom fronts @ 3" - so that was fine
I agree - the std dumps on the R32 GTRs are AVERAGE at best
IMHO - save your pennies - do it once and do it right
changing dumps is not an easy exercise from what I've seen - (almost as much to fit them as it is to buy them) I had mine done while the engine was out - easy :rolleyes:
  • Replies 72
They certainly exist:  ARC makes a titanium front pipe, and these ones are constantly for sale on Yahoo JP.  Only problem is none of the titanium ones seem to be the split design.
I haven't come across titanium dumps, however.
Edit:  I would imagine that titanium dumps would cost a fortune given the thickness of metal required.
Lucien
my oh my. those titanium front pipes look very tasty, but at around $1000 in japan they are far from cheap. I will still be going the trust set-up when I can be farked. from the results I've seen with them they appear to be the best set for the money.
Do it. go on do it. you know you want to :rolleyes:
If you think that's expensive, you should check out the proper ARC items (the Yahoo ones look like knockoffs) -- up to ~A$2,000:
http://www.arcinter.co.jp/titan.html :D As for "do it once, do it right", the problem is I have a noticable leak that needs fixing soon. It won't be a good 6+ months till I get around to the Trust/Greddy units so waiting is not the preferred option.
PSI_GTSII: I'd love to know too, perhaps Nick or someone from UAS can shed some light on this. My guess is you would need the front pipes off (obviously) and perhaps the oil return pipes. I also expect you would need access from the top: probably the removal of air pipes and heatshields??
Cheers,
Lucien.
go for option 3. buy the trust dump/fronts now and worry about the cost later. then you can fit them and tell me how hard it is to do, and what difference they made :D
if you are deffo goind to upgrade later then just buy some stock front pipes. I'll sell you mine for $250 :)
go for option 3. buy the trust dump/fronts now and worry about the cost later. then you can fit them and tell me how hard it is to do, and what difference they made :)
I would buy them, but I am too poor plus I will be quitting work in a month or two until my honours thesis is done, so I have to save for other things :D
$250... you sure you don't want to make that $1100 so you can buy the trusts :)
LW.
Ok heres my Noob question for the day.... :D
Would this item below be all thats required to replace my Standard Dumps and Front Pipe?
http://www.nengun.com/catalogue/product/85
Would it bolt up to standard turbos for now, and then bolt up to say a pair of 2530's or GT-SSs that I may fit infuture..?
The page you requested Catalogue no longer exists, is not available or has been moved.
Please login or create an account and search the product catalogue for your request.
Redirecting you to the index page in 5 seconds.
Argghh...crap :D
Hows this:
If anyone has delt with the HKS Twin Extention kit (BNR32,BCNR33, BNR34 Part No 1418-RN005) then you will know how good the qualitly is. Hard Core steel built to withstand the harshest punishments from those HKS Turbos. Unlike the HKS Extention kit which are two small pipes that bolts onto the turbos then they are attached to the frontpipe which is made from a thinner metal, these Greedy Extentions pipes start where the HKS pipes finish and continue all the way to the cat still using the high density steel as HKS does. Trust Has tested these Extention pipes to handle over 700PS.
Product Code Price Delivered *
11920300 AU $ 893.65
AU $ 1,112.55
Extention Front Pipes 80mm
Compatible with Nissan - Skyline R32 GTR - BNR32
Richard: You remind me of the lawnmower man :(
PSI_GTSII: Yes, those are the Trust/Greddy front extension pipes everyone is drooling over (and that Ronin has). They replace both the dump and the front pipe. A very similar setup is made by CES Racing.
Ronin 09: Its so confusing. They are branded as Greddy on the Trust website :D
CameronBNR32: Link?
Lucien.
I have just finished installing a set of Competition dump pipes from CES to my car. With no other changes, I would honeslty say the turbos kick in almost 1000rpm earlier giving a much needed midrange boot. The whole car seems to breathe better and you don't have to give it that little extra to get the good part of the power band.
Apart from these (dump pipes and front pipes) I am only running pods and Nismo cat back exhaust and larger intercooler. I am still running the standard boost! The car really feels like it wants that extra boost now, and is going to fly when it gets it!
These pipes were a great investment for my car and I highly recommend to anyone else the the CES product is the goods!
yep trust/greddy... just choose a name dammit!! I don't know why, but I think Trust does all the mechanical engine stuff, and Greddy does all the electronic / more 'bling' stuff - turbo timers, gauges, etc etc
edit; actually I have no idea how it is branded...
trust appears to be the head coy, with sub brands greddy, grex, gracer??
I think they look fine. I don't see a big issue with front pipes - they are simple in design and the difference in flow between one and another is marginal.
Whereas I think that the design of the short dump is more important
2c
Could'nt agree more which is why I may just get my local exhaust shop to knock the front pipe up.
$820 for pair coated dumps and $500 (approx) for the front pipe
So the HKS /Trust...whatever ones from Nengun are a fair bit cheaper then...!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
