Yellow GTRs are soft :P
I reckon its great to see them out there giving it some, Wakefield is a tricky track to get a quick time, it is certainly not all about power there...I take it the quick cars were running slicks?
  • Replies 58
just to clarify MR WRX has had over 100 runs at WSID and is driven everyday
the reason the gearbox failed was due to a dodgy billet rear input shaft
which wasnt made to the exact clearances that were needed
its a real 10 second street car and driving it along you would not pick
it its one of the most comfortable, smooth cars ive been in
and the way brian punishes it all day everyday i am shocked that it lasted this long
diablo is also very smooth and easily street driven he regularly drives it from canberra to sydney and has no problems with it
the reason it failed was because TRP made the mistake of using a copper head gasket when they were told not to
I happily stand corrected:D Bit of a bummer that they both failed, but using a copper headgasket on tough car does seem a bit odd. Look forward to seeing the results in AutoSalon Mag:D
to clear things up
the FTR ran 2 10.9 second passses on street tyres and low boost as it was running a standard geabox
it also ran the fastest lap tim of 1:08
it also did 540rwkW on pump fuel with a shot of NOS
its a VERY relaible car that had NO problems on the weeknbd
also OSMANS didnt win the braking- the blue S14 did without ABS and standard brakes with bendix pads....it beat the STi by 4metres
the GTR was also the only car to have full engineering certificates for the car. it did well i every category except fuel efficiency but what do you expect from the curent autosalon power recoird holder?
and before you ask yes i was there as i was competing
hence them both leaving and going to a different workshop
TRP is closing soon anyway
WTF?!?!?!?!?
Congratulations :(
Adrian
the GTR did run but i cant remember the time
MR WRX has done a 1:04 last time he was there not this time and yes it was the full track
LOL...i have to ask/:(
Who was their to witness/time this 1:04. Considering that quicker then any road car i know of and quicker then GTP WRXs with fully sorted suspension, professional driver, and good response/traction... i have to say someone is talking it up massively, a bit liek me when i say i can do 1:10s around Wakefield:)
As Duncan says, Wakefield is not a power circuit, and a 10sec WRX suggests the thing would be rolling between many of the corners looking for boost?!?!?!?! I have no problem believing it could maybe do a 1:08 or higher, but yeh...ill wait until i read the article...the more i think about it i think the timers may have been helping out a few of the cars with a second here and there:)
Australian Performance Cars - Qualifying
Qualifying Q6 30 Mins
Scheduled Start 10:45
Page# 1 Issue# 1
Start Sat May 14 10:45
Elapsed Time 30:00
________________________________________________________________________________
_______________
Pos Car Entrant Driver Vehicle Cap CL Laps Fastest...Lap
1 34 Delphi/King Springs Mark King Mitsubishi Lancer Ev 3395 11 11 1:04.2313*
2 4 Readymix Gary Young Mitsubishi Lancer Ev 3395 21 20 1:04.4006
3 21 Century 21 Real Estate Garry Holt Mitsubishi Lancer Ev 3395 18 4 1:04.5436
4 11 Rondo Building Services Barry Morcom Mitsubishi Lancer Ev 3395 23 21 1:04.8141
5 22 Jack Hillermans Smash Chris Alajajian Subaru WRX STi 3390 18 10 1:04.8182
_______________
Do they run slicks?
to clear things up
charles told me osmans won it.
as for the GTR funny thing was they kept changing the car before every test
it was loud as all *** when it was on the track and you could smell the C16 but when it was in front of the engineer funny how it only hit 88db.
brians car has mountains of torque because its a 2.5 and isnt a laggy bitch either due to the turbo not being massive like his other car (NOCOMP)
its a every well sorted car and he is a great driver and knows the circuit very well.
the 1:04 was not at the SCOTY day which i said in my earlier post.
the only S15 there was jerrys one
there were to S14s though
please dont tell me it was MR dori dori in the blue one
because he locked up and ended up almost doing a 180 cause he tried the hand brake
the only cars that needed a warm up were the autostyle cars LMAO
street cars that need to warm up thier tyres and brakes before going out LOL
****ing pathetic
    • I think in the modern era we live in, if I were converting a hydro lifter head to solid, particularly when chasing revs, I'd be seeing what I could do to use shimless buckets. Those of us with Neos usually have this persistent niggling fear of a shim getting spat out and ruining everything. Shim-over is...yucky that way. At least the Tomei kit appears to be conventional, but it would still be nice if they'd decided to go shimless.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
