thanks Will,
The car is getting worked on anyway, rob didnt sound to happy as he didnt expect that much work and he doesnt have all the parts. So he is going to write up a list of what i have to get or hire. Anyway his going to work bit by bit everyday so its going to take a while now.
Just got my R32 GTR serviced by Will yesterday, fresh off the boat.
Did oil, oil filter, sparkies, and flushed radiator. Will takes time and care with your car, he's not out to get as many ppl thru the door as possible to make more money like a lot of workshops.
Wouldn't hesitate to recommend his services to anyone!
Got the oil changed on the weekend by Will, Top bloke, top service, he really takes his time and makes sure everything is done properly, definatelly going back to get sparkies replaced and coolant flush for the next service.
Cheers Will.
  • 2 months later...
  • 4 years later...
holly thread revival batman.....
maklaw mate if you need advice either ask for it on the wasteland thread or get in touch with a workshop and they might be able to sort you out
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
