Guest GR33DyMANGO
i LUV r34gtt;s! thats an awesome car there toby19:)
it looks as though its in great condition aswell. u should ask franks heaps of queries about what you can do to your car. you just need to take a look at his line and realise how good you can make it look. hey franks whats that link to your site with all the picks of your car on it?
btw: franks, i have a picture of your car as my desktop wallpaper:D (its been there for a few months now)
https://www.sau.com.au/forums/topic/7499-my-car/#findComment-110105
hey greedy,
im slowly updating this online gallery with all pics, so keep checking it for more pics... not all of them are up yet though...
http://www.pbase.com/franks
thanks for the kind words, we'll see how it goes. the kit was 3 quarters done for me, i just added the front bar and powerup mods...:)
https://www.sau.com.au/forums/topic/7499-my-car/#findComment-110319
Sorry Franks (my computer crashed last night)
...I'm thinking 0-400 in the mid twelves to thirteens. I would like to be able to interchange the stock components with the aftermarket ones (in case I decide to sell the car perhaps). That means, for example, no section of the body kit will have to be cut out. Do any of you guys think it might be possible to fit a front mount intercooler without cutting out the kit?
Budget-wise...I intend to do things slowly. You see, my wife hates the car and an instant transformation might not be appropriate. A gradual increase in power would be good...and fun!
https://www.sau.com.au/forums/topic/7499-my-car/#findComment-111121
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
