Just thought this thread had to come along sooner or later...
Drifting,
What car do you drift with?
What mods you got?
How have you set it up?
Which track is your favourite drifting track?
Got some GT4 driftin pics?
Now as for me, in the fieild of drifting on this game, I kinda suck, ok, I really suck. I wanna set up my Stagea 260rs up for drifting, can someone tell me how to set this car up for drifting? Some settings?
Cheers,
Chris
https://www.sau.com.au/forums/topic/75093-gt4-drifting-thread/
i use my s5 white garage tuned rx7 that i won with the different coloured front and back rims...lol didnt need to do much to set it up, just tweeked the suspension setup and bought variable lsd.
fav track to drift on is the suzuka mini track, i can do perfect high speed drift off the straight into the first corner and continue the drift onto the second one..and so on. i just do a couple laps and then sit back and watch the replay:D
have tried wackin in a bigger turbo but that just messed the cars balance up. also found that if you drift properly on that track you can get the same times or faster than if you drove normally.
Cheers,
Chris
"original" parts from tuning houses are good, esp the original suspension upgrades, as they are very stiff. and don't require alot of setup for drift.... ohh yeah, and turn of ASM & TC. Also if you want a fast dori racer then the "original" or stage 5 turbo is good as it has a bucket load of low RPM pulling power.
I find the best is my 32gtst. Spring rates are around 13-14 and sway bars at level 6. Turbo is stage 4 or so oh and i give it heaps of initial torque on the adjustable lsd. The only probelm with the game is the steering is too slow, you cant change direction at the wheels fast enough. My fav. track is midfield, with its long sweeping bends you can carry some serious speed through those corners.
I played a bit of GT4 for the first time yesterday, and i was trying to drift the D1 4 door R34, it was almost impossible, i dont think i pulled off 1 good drift. you guys have got skill if you can get the hang of it
Drifting,
What mods you got?
Cheers,
Chris
Pics eh..... pretty shit drfit but anyway
I hate to admit it but my fav car for drifting is the Lancia Stratos with full tune, etc on the track in Monaco ( can't remember the track name ). Before you throw rocks at me, spend an hour, buy and try the car ( if you've got a couple of extra credits to play around with ).
Turn it into a corner at speed, lift the off the gas drop down a gear and re-apply gas and there you have it.....instant drift :cheers: Soooooooo much fun !!!!!
You should play sega rally on saturn then. r0x0r
I like using the Bluebird SSS-X, everything modified to the max except leave standard gearbox and use the crappiest of the free tyres.
Suspension setup:
6.2kg front, 5.6kg rear.
4.5" camber front and 3" rear.
ride height low as possible.
It's a brilliant setup on tsukuba, and the car has a great balance.
gone the dori style with my favourite Toyota, a JZX 100 chaser,
original parts,
camber on 3.5-3 respectively
6kg front and back
sh!test of the sh!t economy tyres.
no aids (a must)
love the autum ring, nice quick tight corners to throw the fat mumma around. n she loves it
Sega rally on Saturn rocked! I still got it somewhere.
Sega what ?!?! :confused:
( Sorry, this PS2 is the first game station I've owned )
BTW How do you take those pics of the cars during the replays on PS2 ??
Sega Rally on Sega Saturn (released 1995)
Save your replay then play it in replay theatre, press select while its playing to take pics. Or just do a photo drive.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
