hey s13drifter,
Still a bit of work to do to get SAU up and running....looking at next month probably.
As for an ACT chapter...well this was discussed...and it's not totally out of the question. What we're doing (for now) is combining NSW/ACT.
We'll see how many ACT ppl actually become official members of the club. If we get the numbers...we can maybe look at forming our own chapter.
We would need several ppl serious about forming a committee....a President, two Vice Presidents, a treasurer & a secretary at the minimum. These ppl would need to be dedicated and available to help & put a bit of work in :cheers:
So, for now we will join up with the NSW guys and organise our own events and stuff in the ACT. If any of you guys have any ideas or want to organise stuff here...then go for it! Just cos we're part of the NSW chapter doesn't mean we have to wait for NSW to have a dyno day or whatever.
https://www.sau.com.au/forums/topic/752-how-many-of-us/#findComment-16915
  • 9 years later...
How many of us do we need to form our own chapter
Was looked at several years ago but fell down in a few areas
1. NSW president at the time did not want it, told us to go ahead and form our own club.
2. There was little interest in forming a separate formal club and doing the required paperwork each year etc.
Considering most tracks are in NSW and the NSW club currently do a good job ofrunning track days etc, there's little reason to form a club to run these events.
If you want to have a cruise, just post it up, you don't need to be part of a club
We already have meets on Fridays, though somewhere warm and with food would be good.
ACT has a banner and a shade tent for car shows already, participation has been a bit low recently. Those organising such events in Canberra have tended to doit once and never do it again, considering the non-constructive feedback from some people who don't even turn up, I don't blame them.
However considering the importance of the territory and growing numbers of skyline owners, I'd like to see a chapter, formal or informal. Considering the growing power of SAU having a presence in the territory where the high level decisions are made could be beneficial if SAU look at taking a proactive long term approach to improving issues for skylines. In the short term maybe meet up at a club a couple times a year to discuss and pass feedback through someone like Shell who can then take it to the NSW meetings.
https://www.sau.com.au/forums/topic/752-how-many-of-us/#findComment-6214502
so wait, are we ditching the skylines and starting a bikie gang now :/
Nooo just putting biker gear on and driving in our slylines :D
Me three.
But only if you put a sticker/logo on your car that reads " Air Force One and a half" :D
Jimmy you make it and ill put it on honestly lol
https://www.sau.com.au/forums/topic/752-how-many-of-us/#findComment-6216484
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
