hey guys
due to the restrictions in aftermarket ecu options , and wantin to take the Hp to another level, im changin my gearbox to manual
i got a price o 2 grand for the gearbox, tailshaft, and clutch fitted
i thought it wasnt too bad.
gettin it done on the 6th of june, hopefully notcie a bit more power, less restriction and a betta quarter time down the strip,
also being able to control corners and power out of them, knowin what gear im goin around the corner in.
i know 1st and 2nd i can control, which i luv but 3rd to 4th and back i cant and really have to stomp the accel to whack it back,
i do admit the auto is fun to drive and was considerin auto quick shift, but tryin new things, and wantin 250rwkw and up, not wantin to go through piggybacks, or full ecu's knowing the gears are goin to be harsh and f@#k it up.
anyway lettin yas know what im doin, and i'll say i'll let yas know how it goes
but i'll prolly forget too.
So pm if ya want .
https://www.sau.com.au/forums/topic/75272-auto-to-manual-for-2grand/
  • Replies 61
well, thats why my car was goin F@#kin slow as down the quarter
gear changes are like 1 sec im loosin
and seeing these ppl doin standard around 13 and stuff
i have FMIC, AVCR on 10psi CES RAcing split dump to cat 3 1/4 exahust
and my best was 15.2, so the 40% power loss sounds about right.
GReat Guns wwoohhooo!!! manual is just around the quarter.
This would be good to show as well of what the power differences are down the quarter.
remember that 15.2 down the quarter in an auto
in a week i'll go down the quarter and i'll see what i do , just to give you guys an idea,
THanks
hey guys
So pm if ya want .
Where abouts u getting it done? Thats mega cheap, are you supplying the clutch cos if not they wouldnt be giving you a good one for that price
....i have FMIC, AVCR on 10psi  CES RAcing split dump to cat 3 1/4 exahust and my best was 15.2,  so the 40% power loss sounds about right.
Baz, just for comparison sakes what sort of power did you get with those mods?
Baz, just for comparison sakes when you actually get the conversion, what sort of power did you get with those mods?
gettin it done through defiant engine conversions
the cost includes
brand new clutch, tailshaft, mod platted and cert, machined flywheel
new oil, drive in drive away
i should get it back tomorow arvo
i dont know the comparison yet, i just went by figures from manual skylines i have seen down the quarter and rwkws to autos with the same mods. approx
i will tell yas when its done , and when i go down the quarter
the cost includes
Includes gearbox as well?
Dont worry SLIDE, some minds will never be open to the benifits of an auto. I guess they spent too much time in their 1980s family auto.
I have to agree with you though, the few who try and give me a run all apear in the rear view vission mirror.
hey guys the manual gearbox is in ,
i havent strapped it heaps yet, as i have a screw in my tyre , and gettin that fixed up today.
i DO notice that it feels a bit quicker, and feels strong
no whines or anythin in the gearbox, he did remind me that it is a brand new heavy duty clutch, and machined flywheel, 5 speed manual from rb25det.
mod plate gettin done this arvo with manual console .
and gettin the auto gearbox back,
so if anyone wants a autogearbox for cheap, let us know !
it was actually 2500 which is still good, and would still work out to 2000 when i sell teh auto and tailshaft and torqueconverter.
but yeah i reckon its worth it , and power fc is l8er to come.
and also down the quarter times very soon .
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
