Hey all, i searched and searched and didnt find much. I have an r33 Rb25det and i just reached 300 kw on the dyno yesterday after the next stage of my mods. Although it was only on 18 psi i am worried that i have pushed the standard internals as far as they will go...Without breakage.
What kinda power and boost is everyone running on standard internals?
Or does anyone know how much the bottom end will handle?(approx 90,000kms)
https://www.sau.com.au/forums/topic/76363-bottom-end-strength/
dont know for sure but things i have read you shouldnt push them past 300 rwkws on a standard bottom end . Iam in the hunt for those sort of figures and have just about finished my rebuild( flogged out valve guide) with fordged pistons and rb 26 rods so i hope it will be strong. Congrats on the figures to thats great.
Sydneykid Rule of Thumb (yes another one) for an unopened RB25DET is 450 bhp, that's ~280 rwkw. So you are already past where I would start looking for signs of distress.:)
Over the years we have developed a standard around here.....
BHP = Brake Horsepower, which can only be measured at the crank, on an engine dyno if you like.
RWKW = Rear Wheel Kilowatts, as measured on roller dyno (Dyno Dynamics being the most popular in Australia)
BHP / 1.34 - losses = RWKW
:cheers:
PS; it is much easier if everyone uses the same language.
SK:- What usually goes wrong if you go  over your suggested power limit(280rwkw)?
What do you suggest are the most important parts to strengthen when aiming for 350RWKW??
Things I have seen fail;
Piston ring land
Piston crown
Head gasket
Little end bearings
Conrod bolts
Big end bearings
Main bearings
Exhaust valve and seat
The #1 part is pistons, #2 is conrod bolts, #3 is the conrods themselves. Head gasket can be an issue on older engines, head studs are a good solution. Upgrading the bearing material is important and main bearing studs are worthwhile.
Actually the only thing I have not seen fail is the crank, they are blooody strong suckers.
Hope that helps some more:cheers:
SK- What bearings do you use, and what studs do you use for the main bearing girdle?
We used to use Clevites but they must have done an exclusive deal with some Jap Tuning House, so we now use ACL Race Series, great results so far.
We only use ARP studs, never had a problem with an ARP product.
:cheers:
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
