Hey peoples,
I have an R32 gts-t with climate control....now the aircon works like a breeze and cools excellent aswell, however lately it has been playing up.
While the a/c is turned on after a while the air goes warm and i mean warm.
i dont think its the climate control adjusting the temp because the air coming out is very warm.
when i switch it off and turn if on again after awhile it cools great again....does anyone have a clue what needs to be done? is it just a simple re-gassing or something more?
cheers
https://www.sau.com.au/forums/topic/76606-r32-aircon/
  • 3 months later...
I know this is a really old post but I just thought I'd let you peeps know that I recently pulled my aircon compressor off and took it to a guy in Milperra ( NSW ) who replaced the electro-magnetic clutch for $120 ( including labour ). Add to that the cost of re-gassing the A/C system after installation ( usually around $80 ) and you have a $200 total :D Not bad when you consider that a NEW A/C compressor from NISSAN will set you back more than $1,200
Do your homework and it will pay off BIG TIME like it did for me.... It took me a couple of months to find this guy but well worth it :D
https://www.sau.com.au/forums/topic/76606-r32-aircon/#findComment-1607911
  • 6 months later...
For those interested -- and for the sake of propagating the guide in a few related threads so its easy to find with the search facility -- here is a guide for removing the windings in-situ on an R32 GT-R (I imagine its much the same across the R32 series and probably for 33s and 34s).
http://www.skylinesaustralia.com/forums/in...howtopic=112597
https://www.sau.com.au/forums/topic/76606-r32-aircon/#findComment-2076849
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
