If you believe that all Jap made bling items are best DON'T READ BELOW.
Flow Bench Test Results RB26 Exhaust manifolds. Test were done on a proper flow bench test at 25 inches of water. All figures are CFM.
UAS Extrusion Honed Factory Manifolds..................182.7.........167.4.........179.3....
Factory Manifolds.......155.7.......138.2...........150.1...........
Stainles Manifolds......160.4..........138.8.........170.0
To further put in perspective the extrude honed ones are also match ported and different amounts of extrude honing is done in each runner to bring up the most restrictive ones and less on the better flowing ones. Flow bench tests are done to test before and after. This helps even up and balance the motor when in real time, whilst increasing overall flow. Less restriction means less heat and more free power and less stress on the motor.
................... Max Variation...............Average.
UAS Extrude Honed.......15.3..................176.46
Stock..........................17.5 ................148.0
Stainless.....................31.2 ................156.4
Plus stainless manifolds are more likely to crack, they do radiate much more heat and can't be HPC coated to well if at all. Can't improve on stainless unless roughly made and have jagged edges which these did not, and can't extrude hone. More prone to cracking.
Factory ones unlikely to crack and don't radiate as much heat and can be high temp black coated so will flow a fraction better in reality and perform better as they won't cook the comp cover as much as stainless. As a general rule of thumb every 7c increase in temp you lose 1% of power and require larger intercooler to cope with increase in air temp coming out of compressor. Best part is much cheaper than expensive Jap Bling ones. It is possible that other stainless manfifolds perform better although I don't think they would.
We have simlar results which we will release soon for RB25 manifolds, waiting for the extrude honing to be done on a set to get exact figures. We have figures for stock and two stainless types tested.
Pic are stock manifolds extrude honed and high temp HPC coated.
  • Replies 98
Retail price is $520 a pair. Cheap compared to stainless ones and much better result, and when they are in your car you don't see them anyway even if you are into bling. A fair bit of time and money spent making flanges and jig for the manifolds to go on the machine. Note also this is Extrude Honing not power porting or sand blasting. A thick gritty paste is used on a big Extrude Honing machine and it pumps the gue forward and back for hours to get much smoother. This is done after match porting which also achieves gains although from flow tests results only about 1/3 of the gain. If you are on a budget though and your engine is apart you should at least match port to head and turbo.
hi john is that HPC coated as well or just honed?
No just honed prices and specs etc are here.
http://300zx.com.au/pricelists/pricelist_g..._gtrexhaust.htm
since this is in the tech section rather than sales section, Can someone or you John, explain exactly what is "extrude honing"...
what does it do?
how is it done?
also, are the RB20 and RB25 exhaust manifolds identical?
thanks.
http://www.abrasiveflow.com/services.htm
Not sure if same?
I'm glad this topic has come up again because I was going to post a question about GT-R manifolds in the original thread about extrusion honed manifolds that John posted. Despite having pulled apart the exhaust side of my car all of about 2 months ago, I think I'm going to have to do it again as I think the rear manifold is leaking. Its a shit of a job, so I am looking for an incentive ;)
was the Stainles Manifolds, just a china copy style one, or was it something brand name like HKS?
I'd like to know that too. "Stainless manifold" isn't terribly descriptive :stupid: John: are you able to clarrify exactly what brand the stainless manifold was?
AFAIK, the main options are:
1) Keep the stockers.
2) Go for the UAS extrusion honed versions.
3) One of many jap. manifolds.
Of the Japanese, the ones I have come across are from Silk Road (~$500 + delivery/charges), HPI (~$1500 + delivery/charges) and Garage Saurus (don't recall the cost): unfortunately none of them have any flow data on their websites.
To those who have replaced/changed their manifolds (with twin lowmounts): what did you use and what benefits did you notice?
Cheers,
Lucien.
I see.
fancy word for sanding..
hahaha just kidding.
so instead of some sort of rought material, your company or people you use for extrude honing, is using some sort of "gritty gue" to get an even more smooth surface inside the exhaust manifolds.
Apart from the CFM figures, will you be able to provide a RWKW figure for those of us that will be after dyno figures (not me but I'm sure you'll find the same thing here as with the plenums)
will you eventually get a GTST or GTR with stock manifold and only replace the stocker with one of your modified ones and have before and after dyno readings with everything else being equal like boost etc?
You also mentioned that you do different amount of honing on each runner to bring up the most restrictive ones..
and yet the CFM results still show uneven amounts per runner.
using your results above of...
Factory Manifolds....................................................155.7.........138.2
........150.1.....
that is an increase of ............................................27.0............29.2...........29.2
That's not exactly that different amount of honing per runner.
I may be mis calculating something..
correct me if my example is wrong.
also, when extrude honing an exhaust manifold, are you aiming for "EQUAL" CFM for each runner? and also trying to get MAX cfm when doing so?
so in a perfect world, would you have wanted all 3 runners to have 182.7 CFM figure?
cheers.
sorry for all the questions.
gotta learn somehow.
So you're not sure what you / someone you're contracting to do the work for you, is doing exactly?
They are exclusive to us we are geared to retail and answer questions and send out and do exchange etc and James from Abrasive flow is best at doing the work, so we keep our hats on at what we are both best at.
GTST It is not possible to get all runners the SAME we aim to getting them much closer as you can see.
I don't know the brand as nothing on them apparently and I did not see them myself. They were not new ones. If anyone has some stainless ones we will test at no charge and report results.
Hi John, this might sound like a strange question, but which way did they test the flow? In the direction of the normal exhaust flow? If so, how did they block off the 2 cylinders they weren't testing? If they blocked off the 2 non testing cylinders at the cylinder head flange, then I am not surprised that the centre cylinder flow less. The aerodynamics of the manifold would cause that.
The only real way to test flow equality it is with all three cylinders being used in the same time frame as the cylinder firing. But that would be difficult as the primary runners are not the same length, hence the pulses would reach the secondary pipe at different intervals, ie; create interference.
Perhaps a better porting result would be achieved if the primaries were of equal volume, as this would give the same result as equal length. That is where flow testing of equal length primary pipes, as you would find in any decent stainless steel pipe manifold, won't show up their true advantage. Flow rate is not the only gain to be had from equal length primary pipes.
An example, the GTSR Group A exhaust manifold barely flows any more than the standard RB20DET exhaust manifold, but they make 25 rwkw extra. Why? Because of the extractor effect of the equal length primary pipes.
Bless you GTST, I knew someone had to ask about the main game ie performance sooner or later.
John, I'm not trying to in any way oppose what you have posted here but can you answer Abo Bob's question or not? If I was a bench racer / professional air mover I'd be there this arvo with the $ to get a set of these. But since I only want to use a flow bench to move air to increase performance (and remember air under vacuum behaves differently to air under pressure) , you have given me no real reason to spend money. Please help rectify this for me. Or indeed most of us whom I suspect will beat a path to your door if you can provide results.
Or should the start of this thread read' all those who are prepared to spend their money on something that moves air really well but has not been proven to increase performance read further'?
I'm a fan of the original manifolds for the reasons you have stated. Prove to me that the extra money to get them honed actually works in the real world and you can have my money today. Or tomorrow, whatever works for you. Alternatively, tell me what you reckon I should see at the wheels + or - 10% and if you're right I'll pay, if you're wrong I don't but you can have my old manifolds. If it works this is a no risk proposition for you.
Remember, no offence meant.
Regards
Hmm, I haven't posted in here yet Scooby.
John, another contentious thread. You can't help yourself :).
SK, no it's not a perfect test but what is?
It seems to me that the only proof people here will accept is:
1. Dyno car.
2. Do the manifolds.
3. Dyno the car again.
4. Overlay the two runs.
5. Post it up.
I would personally have no problem with a retune of whatever engine management you have in between 2 and 3 but some might.
Some pertinent before/after temperature measurements might be helpful but difficult to provide.
Guest Mashrock
yeah i found that on my car it still uses the factory ones, and also the factory dump pipes too.
but yet the car does make alot of good solid power
and is quiet possibly i could already have some type of modification to the std extractors like this.
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
