hi guys..i just want to know if anyone has really dumped the front end of their r32, mine has 19inch wheels on it and she scrubs out quite a bit now on the plastic thats under the wheels wells...is it aiight to rip the plastic out completely?? or will it look shit under the gaurds..i also has to do a bit of body trimming to help the rubbing
regards luke
https://www.sau.com.au/forums/topic/77691-really-low-r32/
Low is slow:cheers:
low is not always slow, but maybe in this instance it is
is it professionally lowered?? if not have the wheels been balanced and aligned?
cause if it is that low that it is rubbing the inside of the tyre might wear away and then blow out and then cause lots of trouble - accidents, dead people, manslaughter charges etc (very very nasty stuff)
https://www.sau.com.au/forums/topic/77691-really-low-r32/#findComment-1420850
its pretty low..my front gtr bar is sitting 72mm off the ground. the wheels dont show any camber i have only dropped it 1.5 inches i have GAB coilovers and just wound them down a bit..the inner plastic just scrubs on the top of the tire when i hit bumps on the road. and when i i go around a corner and hang the arse out (powerslide) the wheel just rubs on the actual gaurd itself i think due to bodyroll....to eliminate all of this i would it be recommended to just rais it .5 inches, and buy a bigger front sway bar to stop the body roll, and mould the plastics up a bit or just rip it out...in affect of ripping of the plastics will this mean when rocks flick up under the gaurds can they dent the actual gaurds???
https://www.sau.com.au/forums/topic/77691-really-low-r32/#findComment-1420911
I know a lot of cars not running the inner guards.. with wide body kits etc.
Stone etc dont dent the guards.. but you need to make sure the wiring is sealed well and there are no holes the enter the inside of the car... the water flicking off the wheels gets in even the smallest hole.
https://www.sau.com.au/forums/topic/77691-really-low-r32/#findComment-1420934
Too low is slow.
By removing the inner guards panels you have noticeably increased the aerodynamic drag, thereby lowered the top speed, reduced the acceleration rate and increased the fuel consumption.
Shall I get into how much power you have lost in excessive drive shaft angles? Nah, it's not realy necessary because everyone knows that:cheers:
https://www.sau.com.au/forums/topic/77691-really-low-r32/#findComment-1421053
I can't see you going fast speeds/hr on undullating semi-country road with 19's and 7cm off the ground.. Like the other night stuck behind some clown with a u-beaut body kit.. he was holding everybody up because of being worried about his precious bodykit dangling cm off the ground. What is the point of having a fast car that you can't push because you are worried about the bodykit scraping the ground, or can barely corner properly. All he did was shit people off.
So ok, all its good for is tough laps.. fullsic.. cops love lappers too
https://www.sau.com.au/forums/topic/77691-really-low-r32/#findComment-1421105
ok fellas just raised the car 10mm, she doesnt scrap anymore no need for me to rip out the inner gaurds...but since i drift the beast a fair bit im gonna get the sway bars anyways...thanks heaps for your input
regards luke
Drift on 19s?? shit u must be rich :)
https://www.sau.com.au/forums/topic/77691-really-low-r32/#findComment-1423199
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
