hello
How are we all i have a mate who can get cheap stuff through whiteline so like strut braces and suspension etc.
The more ppl we can get to buy sum gear the cheaper it will work out for evryone.
So im looking for interest in whitline gear as you know this stuff is top quality and comes with warranty.
I can find out prices asap just let me know what you want and also rember the more ppl the cheaper you can get it.
thanks
email [email protected]
https://www.sau.com.au/forums/topic/77794-brand-new-whitline-gear/
Remember that Skyline Australia club members (well, in NSW at least and I assume other states) also get a discount from Whiteline.... depending on what Andrew is able to negotiate, it may prove easier to just join your state's club.
good point lwells well i will get my prices and i will send ppl pms if its not that good i will jsut take this topic off, but it should be good as i ahve alot off ppl asking for gear so i should be able to get it bit cheaper.
thanks
thanks
Its definately $50 well spent (joining the club I mean). Even if the g/b falls through (which many do when it comes time to cough up the dough) you can still get a discount ;) Do you often give people PMS? :)
Lucien
Closed.
If you wish to organise a group buy in future you need to be specific on what is available and the price being offered.
A simple "my mate can get stuff cheap" isnt acceptable and becomes too messy too quickly.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
