I can get 7 AP engineering power fc to suit R32 GTST for only $1120 delivered each.
This price doesnt include the hand controller.
If you require the hand controller then the total price is $1440 delivered.
These are ready to be shipped as soon as each payment has been made. No pre order, no waiting.
Come with 12 month warranty
This is only available for a week or if the 7 units sell by then.
Close date - 29/06/05
Buyers
1/ private buyer - Paid
2/ nF - Paid
3/ $$slowmedown - Paid
4/ B0oStEr - Paid
5/ nytrda - Paid
6/ - - - -
7/ - - - -
https://www.sau.com.au/forums/topic/77926-r32-gtst-ap-power-fc-group-buy/
  • Replies 42
Hey Paul,
Im very interested in one for my R32 GTS-T, But before i hand over any money can You answer 3 simple questions for me:
1) Are these brand new??
2) Is there an A.P Engineering power fc Key Ring in the box??? as i heard thats a bonus of this version.
3) can you quote the modle number of the A.P Engineering power fc for me.
Thats and excellent price, best i have seen by a few hundred.
Thanks
Greg
Hey Paul,
Thanks
Greg
Hey Greg,
1) Brand new with 12 month warranty
2) Not sure but will find out.
3) part number - 4E14N07Z
Price bump!
with commander - $1420 delivered.
without commander - $1115 delivered.
First 7 confirmed payments are ready to be shipped.
Payments can be made instantly and the units will be shipped as soon as individual payments have been received.
The power fc pro is designed for drag racing use.
These units have 2 additional functions over the regular units:
1. Ignition cut used for rev limiter - Regular Power FC cut fuel feed when the preset rev limit is reached. At high rpm there is the possibility of knocking when the fuel is cut in high powered cars.
The Power fc Pro cuts ignition at the rev limit to prevent knocking that could potentially destroy the engine.
2. 0km/h rev limiter setting - Allows for the setting for an initial rev limiter that is active whilst the car is not in motion.
This allows for maintaining a rpm level for constant launches.
:rofl:
can u use a hand controller from a 33 or is it different
Confirmed - The R33 GTS-t commander will not work.
ECR33 H/C- P/N: 415-X001
RB20 DET AP Version H/C- P/N: 415-N001
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
