Finally got the Tomei 260 duration with 9.15mm lift (IN/EX) Poncams installed and tuned yesterday.... I must say that these were are worthy upgrade, not only did it make more power from Idle to rev limit, but also brought the power on earlier!!!
Mods include common upgrades (PFC, 720cc inj, Nismo AFM, full exhaust no cat standard dumps ;) , 044 pump, Trust T517Z8cm2 turbos etc...)
Power before cams: 335rwkws (20psi)
Power after cams: 365 rwkws (20psi)
Very happy with the result, was expecting around 15rwkws increase so to get an extra 30rwkws was music to my ears!!!!
Trying to dig up the old dyno sheet (335rwkws), but here's the new one for now..
dyno12.jpg[/img]
Now to really impress all you guys I got Ben (Racepace) with a lot of arm twisting to do a run in 'shoot out' mode... With my understanding (correct me if I'm wrong) shootout mode has a different inertia setting (100 compared to 0) and also adjusts the air and intake temps....
Here's the result:
dyno2a1.jpg[/img]
WOW!!! Where did the extra 31rwkws come from???? Reason for this graph to try to point out to Stacey (two.06l) what the difference between 'shootout' and 'non-shootout' figures are...
And finally for pnblight and all the boys out west:
dyno3a1.jpg[/img]
Dyno figures to me are more of a tuning tool, not to show how big your wanger is as each dyno is different to others. As long as you keep using the same dyno to monitor gains/losses through ugrades, and more importantly to make sure ur engine survives!!!!
P.S No harm inteneded in any way, shape or form to anybody mentioned in this thread.....
nice one mate. from the third graph, i must say your wang is at least 16inches on the slack... hmmm.
seriously though, that is a nice looking curve. was there any tuning needed with the new cams? (i'm guessing yes). if you know, what power did they make when first installed (ie no tuning changes), also was there any fiddling with cam gears to change the power delivery or were they pretty spot on at 0 and 0?
enjoy ;)
Beer Baron, just with the cam install (no tuning) I think the power went to 348rwkws, will have to confirm with Ben....
I know he definetly tweaked with the cam settings and tuned to suit to get the 365rwkws...
Not sure with cam gear settings either, but he definetly played around with them....
G'day Jack!
I have also recently had a set of these cams fitted with, like you the assoc. goodies to go along with it, and will post full results shortly...(need a stronger clutch before going to 1.4 BAR)
I would like to hear back from you (as would others) as to the settings used by Ben for the cams... I currently have 0 0 set but I am running HKS GT-SS turbos, so there may be a difference there....
BTW what are the TRUST turbos rated at?
cheers!
Wow, thats some serious power, now to put in your sig '400kw@wheels' just to make sure people know your wang is big. j/k
Good to see real word differences between normal mode and shootout mode on bens dyno.
williamsf1 - I'm not too sure with cam settings, but I'll find out and report back... These turbos are rated at 320hp each....
R32-GTS - boost is set at 20psi
ferni - just wanted to 'enlighten' people to the differences in dyno graphs getting around the forums.... I'll have to take u for a burl on the next track day!!!
Nice one Jack. Dyno graphs ain't dyno graphs as they say.
May be time to throw in a PFC and injectors and get a little extra myself, Benno alluded to a bit of a lumpy idle at Sandown (and it seems that way) but no idea what's in there as far as cams go. Could have used some more oomph yesterday.
For sure, its good to see side by side shootout vs normal dyno sheet... Would of been good to get Ben to also do another run with the IT temp sensor stuck inside the pod filter at 50deg or something stupid ;)
Looking forward to the ride... hopefully the cooler pipes stay on this time - did you get them fixed up? ;)
super impressed with the result for 320hp turbos!!! my GTSS are supposedly similar in output, so interesting times ahead!!!
I take it stock 80k odd engine also?
can't wait to hear about cam timing.... it is certainly opening up a can of worms up this way!
Jagr33 very nice
I copied the shit that it can't have done that but you have prove it that a nice combo well tuned, will make the numbers and the only different i see is that i got garrets and jagr33 is running trust turbos. Good shit and enjoy as i have done hehe. Whats 2.1 rwhp between friends you must be loving buying the tomie poncams cams YES?HEHEHE
I put a set of PONCAMS into my 180 and got similar results.. Now with the GTR I am considering going for even more lift than the PONCAM can offer, in terms of percentage increase I want to go with the PROCAM 260 deg 10.8mm lift, keep my boost at 1.2 bar and try and get some more power in the mid range and hopefully drop my max torque from the current 6000rpm that it is now.. This is really good to see the PONCAM increase so that I can more understand what to expect from the PROCAMs.. I will be running desktop dyno simulations soon, I did some for the SR20 and the results were very similar, so I am hoping that I can get good results with the RB26 model that I am working on..
I wonder if 10.8mm is too much lift??
PS. Your schwartz is also long like your wang.
rob 82 - sorry no graph of power vs torque
ferni - yeah cooler pipe sorted, especially after about 20 runs on the dyno!!!!
purple32 - cheers mate, will have to organise a cruise soon....
williamsf1 - engine has forges pistons and metal headgasket, about 2,000k's old... intersted to see how you go with your setup, keep us posted!!!
Morgs - contemplating on taking it out to see what time she pulls, although my car is a dedicated track/circuit car, and also don't want to munch the gearbox.. I know, excuses, excuses!!!!!
pnblight - thanx mate, thought I'd chuck in the last graph for you westies to understand and compare....
Yorik - I know of a local car running exact same setup as me but with 10.8mm lift 260 Procams, not sure on power output, but these cams obviously need modification/machining of the head to accomodate...
Be interesting to see your results....
No machining necessary, change the springs to Tomei Type A, change lifters to Solid type and reshim accordingly. Which I am more than happy to do as I am lifting the head to change to a stainless gasket anyway.,. Also putting in the Oil restrictor at the same time amongst other things.
That car that you know of, it would be good to know what sort of power range it has, not so much power output, but the usable range, maybe even compared to yours.. I won;t be doing this to my car for a while, but you can be sure there will be full details..
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
