  • Replies 95
Do i get a cookie  :Pimp2:
:cookie:
tommyk I don't see why not:
the highest peak was 253kw but we settled on the 247 as it made more midrange than the 253 setting.
COOL
What mods do you have and was that run done in awd or rwd mode ?
You guys suck. You make me want to buy a pair of GT-SS's :D
as for mods mine is still stock turbos, stock cams, stock intercooler, stock dumps, stock front pipes. just 3 inch cat back system, apexi pods, cam gears, 14.5psi boost, and power FC. obviously have other unrelated stuff like oil cooler, twin plate clutch, OS gearset etc etc. the first graph showing 221kw was before the cam gear adjustment. in the process of adjusting the gears boost also rose by 2psi (without touching the controller) and the AFRs leaned off a bit (also without touching the PFC). so that may have influenced the gain a little too.
is that graph rwkw or awkw ?
Why do I ask ?
Ive got everything you have including 15psi boost, aftermarket front pipes, but i dont have the pods or gears
Sorry for the hijack kabab
sorry mate, it's in rwd. so outright power i would say it's pretty much the same between us (i don't know really) but the shape of the curve is what is most important to me at the moment, not the peak figure. :D
I noticed when mine was on the dyno it was in full 4wd mode so i guess thats why your figure is much higher then Tommyk's..
What would the difference be between awd and rwd power wise?
to be honest i really don't know. i have heard lots of stories. some people say on a 32 GTR the difference is negligible (something about the way they divert torque to the front wheels on a dyno), other say about 30kws difference. personally i think there must be some difference but how much i wouldn't want to guess.
Suffice to say that, as always, a dyno is not the best dick measuring tool as everyone has a different ruler.
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
