  • Replies 95
Do i get a cookie  :Pimp2:
:cookie:
tommyk I don't see why not:
the highest peak was 253kw but we settled on the 247 as it made more midrange than the 253 setting.
COOL
What mods do you have and was that run done in awd or rwd mode ?
You guys suck. You make me want to buy a pair of GT-SS's :D
as for mods mine is still stock turbos, stock cams, stock intercooler, stock dumps, stock front pipes. just 3 inch cat back system, apexi pods, cam gears, 14.5psi boost, and power FC. obviously have other unrelated stuff like oil cooler, twin plate clutch, OS gearset etc etc. the first graph showing 221kw was before the cam gear adjustment. in the process of adjusting the gears boost also rose by 2psi (without touching the controller) and the AFRs leaned off a bit (also without touching the PFC). so that may have influenced the gain a little too.
is that graph rwkw or awkw ?
Why do I ask ?
Ive got everything you have including 15psi boost, aftermarket front pipes, but i dont have the pods or gears
Sorry for the hijack kabab
sorry mate, it's in rwd. so outright power i would say it's pretty much the same between us (i don't know really) but the shape of the curve is what is most important to me at the moment, not the peak figure. :D
I noticed when mine was on the dyno it was in full 4wd mode so i guess thats why your figure is much higher then Tommyk's..
What would the difference be between awd and rwd power wise?
to be honest i really don't know. i have heard lots of stories. some people say on a 32 GTR the difference is negligible (something about the way they divert torque to the front wheels on a dyno), other say about 30kws difference. personally i think there must be some difference but how much i wouldn't want to guess.
Suffice to say that, as always, a dyno is not the best dick measuring tool as everyone has a different ruler.
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
