Second issue, I did an oil change yesterday, but when I drained the oil only 3.5 litres came out. Obviously the rest is still in the cooler core and lines. How does everyone else go about flushing the rest of the oil out.
Do these things happen to anyone else, or have I done something wrong? I have definately plumbed everything correctly going by this DIY, so I just wanted a bit of reassurance.
Cheers
Just installed one of these kits, (very helpful thread btw), but very interested to know about this as well, I dont want to have to unplug everything to flush properly. how do you guys do it?
Also, where can i go to get these lines cut shorter(in Adelaide) , they are way too long and taking too much space.
Cheers
go buy a bottle of cheap oil to use...
drain your oil as usual, leaving the filter on...
put the cheap oil through the engine for a few mintues then drain it again....
that should get the majority of the older oil out.
then replace the filter and add your good oil as usual!
I'd rather leave used synthetic oil in there than cheapo flush oil. The issue still remains that there is quite an amount of oil left in the system after draining.
  • 2 months later...
An oil cooler is very high on my list of mods (which will all happen when the car is off the road this June for 2 months). Only question is that it adds extra complexity and I would like to try and make it as bulletproof as possible.
Does anyone here run an over sized sump with cooling fins?
I reckon the extra oil capacity along with the fact that there are no oil lines to fail has to be a good thing...
Edited by Chris_R33GTSt
This is a valid issue^^^
Anyone care to share what they do to get the remaining oil out?
thats why mine is above where it goes into the block. before this, i was unscrewing it and lifting it higher, you will never get it all out this way (at least how mine was set up) but you can get a lot. i change oil often enough that im not worried about the quality of what is still in there.
Added to members tutorials. Nice work. Pity the GTR has stupid BOVs in that spot... my cooler is under the damn car..
Hey Prank
Same issue i have, thought bout moving the BOV's, or replacing with one in the engine bay, but dont want the attn. Would be massively appreciated if you could share where you placed yours! :blink:
- Michael
  • 1 month later...
Well i guess that Lazy Bastard has pointed out the obvious flaw with oil coolers, This is the very reason why i have not decided if i should buy one yet.
Unfortunately unless you have your oil cooler and everything positioned so that most of the oil drains out using good ol gravity , you will always have at least 1 litre
of dirty oil on the sump, yes thats right DIRTY DIRTY OIL hehe just the thought of it... eh yuck Even if there is nothing wrong with that.
Oil coolers do a great job But I would opt for a high capacity performance sump with oil cooling fins anyday. Unfortunately cant find anything like that for RB25.
Come on guys!!!! Surely you don't think you get ALL the old oil out when you do a conventional oil change.
Even if you do a hot change and then leave it drain overnight, there will still be oil in turbo lines, galleries, cylinder head pockets etc.
99% of oil coolers are full flow, not by-pass, so any oil in the cooler will be filtered before it goes through the engine.
If you also fit a remote filter, that filter too is always mounted downstream of the cooler.
So don't panic. Change your oil/filter as per usual and top up according to the dipstick.
  • 1 month later...
The oil cooler in my old 32gtr sat on the left hand side duct of the car, meaning i've almost two metter of braided line run from the oil filter, into the front bar, cross on top of the intercooler and down to the left hand side coner.
As for remaining oil left in the lines and cooler it self, i wouldn't think it should be a worry as long as you drop the oil regularly, dont' forget by having an oil cooler, you've already pro-long the life of your engine oil so if basic maintance is carried out on time, oil will still be good by then.
  • 1 month later...
Attaching the Hoses
Remove the oil filter from the engine and attach the engine adapter. Make sure the two ‘O’ rings are in place. I used a little grease to hold them in place. Take note of the orientation of the engine adapter hose connectors, check the markings, inner and outer, this orientation will be required later. Outer is for the outside of the filter, and the other is the inner of the filter (threaded section). The oil from the engine is pumped through the outer of the engine adapter, through the remote filter outer (small holes with rubber one way valve), across the oil filter element to the inner threaded section of the filter, then to the cooler and returned to the engine via a long hose to the inner threaded adapter on the engine. If the hoses from the engine adapter are on the wrong way, the one way valve in the oil filter will prevent oil circulating through the filter and cooler. Take note of the orientation before you mount the adapter.
ok - excellent guide - i have a couple of questions with this though. im probably overthinking it. but i just want to make sure i get it right.
does this mean the oil cooler is fitted on the inner of the the two lines?
also with the core mounted straight up and down - which way should the lines be going in?
should oil be flowing in from the remote filter to the top of the core - then from the bottom of the core to the engine?
thanks heaps
-Matt
Edited by huddy
  • 2 months later...
G'day ahh 33 s2,
My Skyline had a Blitz front mounted cooler attached. The pipes went through the standard holes in the left wheel arch so there was no issue with the right hand side.
I guess if your cooler pipe goes through the right wheel arch then you may have to mount the oil cooler in a different place.
Maybe someone else out there can help with suggestions???
Cheers
blk33 do you have a front mount when your installing this... as i have a hybrid with hybrid piping and it does seem to pose a few problems??
  • 3 months later...
ok, so have ajust jap kit and i havent installed it yet. since with this device installed, there is extra oil cooling capacity...should we be disconnectiong the old oil cooler from the water cooling system???
take this quote from the trust greddy oil cooler product:
Factory oil coolers are normally small water-cooled devices sandwiched between the oil filter and engine block. These tax the cooling system even under normal driving conditions. GReddy / GREX oil coolers are an excellent addition, and are especially effective in harsh driving environments. By using a similar inner-fin core design as our famous intercoolers, we are able to increase oil capacity, decrease oil temperatures, and extend engine and oil life.
so based on the fact that we have extra cooling capacity now from the oil cooler, should we be bypassing the water factory oil cooler so as to enhance/help the water cooling of the engine???
It would be a messy job to bypass the standard water/oil cooler, I would suggest you just fit the oil cooler adapter plate between the oil filter and the standard water/oil cooler.
Cheers
Rob
as far as bypassing the water oil cooler, all i want to do is put a small bit of hard pipe between the two rubber hoses that attach to the water system. that way the fatcory oil cooler is still there just has no water flowing through it...you cant take it off as there are different conections to go from the block to the cooler and then to the oil filter attachment point. it just seems silly cooliong the oil twice now...
  • 1 month later...
A few tips guys:
make sure you wrap your braided lines in something protective if they touch/rub on anything, they WILL rub through almost anything and cause ou problems.
Also dont worry too much about the old oil problem, its not a big issue as Grigor pointed out. I mounted my cooler with the fitting facing down so every second oil change I simply undo them and the the oil drain from the lines/cooler, problem solved.
Nick
  • 3 weeks later...
  • 3 months later...
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
