  • Replies 378
Sorry it has taken this long!
Results are:
2.85 kg/mm or ~ 160 lb/in
Bare in mind i have used an average of your upper and lower OD's. Although this isnt 100% accurate, it will be in the vacinity of the correct value.
From what I've read, these seem like stock rates. How does it ride and handle?
Don't want to be rude mate, but these are not stock rates... My mate drift GTST32 is about as hard as mine, thing rides like track spec springs and I believe it handles insane, but I haven't driven another to compare. It would be very uncomfy as a daily, you can not physically push the car down at a corner at all, not even bounce it?
Any Ideas? Thanks for taking the time mate.
Ben
Edited by TrikkBen
All good...Im simply using the values you gave me.
For comparison, the first 5-10 rates that are in this thread that Sydney Kid calculated I also calculated using my spreadsheet. All were pretty much on spot +/- 5% IIRC. Furthermore, I calc'd my own spring rates and they were pretty much spot on with what I was given from SK. So I dont believe there's a problem with the spreadsheet...
Ill take another look when I get home and re-calc everything. But when I did calculate them, I checked and re-checked the values as I was a tad surprised going off the pictures.
  • 1 month later...
  • 3 weeks later...
  • 5 months later...
hey R32Abuser. (or anyone in here) can you help calculate spring rates for me?
front:
Coil ID = 14.7cm
Wire OD = 1.8cm
# of Coils = 5
rear:
Coil ID = 7.6cm/6.4cm
Wire OD = 1.4cm
# of Coils = 7
Appreciate the help.
Cheers!
  • 4 months later...
Hi SydneyKid or anyone else, could you please help calculate the (rear only) spring rates of my older model Cusco adjustable coilovers. They are really hard and I want to change springs.
Spring outer dia : about 90mm
Spring coil dia: 15mm
No. of coils: about 7.8? (the bottom of the last coil is sort of a 'split half diameter coil' - see pic)
Please disregard the lower 'helper springs'.
Thanks Ron
Thanks Ron
Thanks mate its not Zero2R, theres no damper adjustment, could be a Zero1, its baaaaad, 18/16 sounds plain horrible when Im told even 8/6 is bad! Oh boy here I was wanting to put softer 6/5 or 6/4 springs in.. Would my dampers get rooted with this low a rate?
Ok so got verniers today for extra accuracy.
Spring wire dia is 12.5mm
Spring outer dia is 89-90mm
No of 'active' coils is 6
Spring rate from a couple of US sites is 9kg/mm and thats for the rear- f**king hard hehe
Hi Gary and others,
I have an S13 silvia with RB25DET conversion. It came with Racing Logic coilovers installed, can you please help me work out spring rate?
This is from the rear:
Coil OD = 84mm
Wire OD = 11mm
# of coils = 6.9
It was sitting very low and was terrible for street, (physical pain on large pothole at 60km/h)! I have adjusted the height up and it is a little better, but still pretty rough on the street.
It still has all rubber bushes too not sure if this makes a difference.
Thanks for your help.
  • 11 months later...
  • 5 years later...
  • 2 months later...
man oh man...old old thread. BUT I have to ask...I have a couple springs I need help identifying.
14" spring front
Coil ID =  65mm
Coil OD= 85mm
Wire OD = 9.7mm
# of Coils =  10?turns
12" spring front
Coil ID =  65mm
Wire OD =  9.5mm
# of Coils =  7.75/turns
10" spring rear
Coil ID = 65.5 mm
Wire OD =  9.5mm
# of Coils =  5turns
I hope that the OP is still doing this!!! I need to figure out these springs and if they wont work for my application I need to order new. Please help!
Thanks in advance!!!
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
