For those of you who don't know, one of the 12 Apostles collapsed over the weekend, leaving only 8 of the limestone rock formations left.
http://www.news.com.au/story/0,10117,15815...0-28102,00.html
If you have not yet driven to Port Campbell to see these, then I suggest you make it a priority for a spare weekend, before there are none left. Since I first saw them on a school excursion almost 20 years ago - the London Bridge formation has collapsed also.
The drive along the Great Ocean Road is nothing short of spectacular - and makes a fabulous weekend away. The Golden Chain motel in Port Campbell even has spa rooms - perfect for a 'wink wink' weekend away :P
As a club, we try to have at least 2 drives down the Great Ocean Road every year - the first having been in March. We'll try to plan another one later in the year to take advantage of nicer weather, and hope that in the meantime, nature plays nicely and the rest of the Apostles stay there.
James
https://www.sau.com.au/forums/topic/79274-and-then-there-were-8/
20 years ago, now you are showing your age! :uh-huh:
I have done the drive a couple of times and enjoyed it immensly. Maybe a remembrance cruise needs to be organised for the demise of the 9th Apostle.
im thinking about going for a drive with my mate down the GOR on Sunday morning depending on weather and if i go out on saturday night
ye no probs dude, my mate should be coming with his R1 and he never takes it out in the rain so ye just depends on the weather and if we go out the night before
any 1 else interested?
Could your arm be twisted to go if weather is good???
Arm is quite twistable, but the weather this weekend is looking quite crap. That being said, I'm sure every man & his dog will take the opportunity to head down this weekend.
I'll have a chat to a few mates and see when they're interesting in making the pilgrimage.
:cheers:
oh & i'll be sure to take the disinfectant :Pimp2:
:cheers:
Nice, Let me know.
jules 0403 24 24 78
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
