I heard rumour from a good source at Ford, that they are currently developing an AWD system for the next Falcon. It is primarily the same drivetrain used in the Territory, but obviously modified to suit the Falc. This means there would more than likely be an XR6 Turbo AWD.
Now Im not a Ford fan at all, but I'll be the first to admit that an XR6 or Typhoon with AWD would be a lethal weapon. If released, would it have the potential to reach GT-R's level of performance and success? I'll be keeping a close eye in the rear view if it does!
https://www.sau.com.au/forums/topic/79926-awd-falcon-turbo/
  • Replies 66
In the present future there is rumours of them putting an XR6 turbo motor in the AWD territory. In an AWD system it would be very very difficult to hold the amount of torque that the motors have the potential of making. Ford would have to make ane exceptional drivetrain in order to hold this sort of power.
https://www.sau.com.au/forums/topic/79926-awd-falcon-turbo/#findComment-1455140
Ford, is currently using the territory as a test bed for it's awd system, but as someone here said getting the kilos down and the reliable drivetrain to cope with it will cost big dollars.
So even if it did comes out chances are a FPV only case, can't see it under $100k and on the wrong side of 2tones, I remmeber Holden once said, when they sticK an awd behind
5.7, then they'll teach the 2.0 litre brigade(wrx) a thing or 2, I'm still waiting. They've forgot one thing reall R&D cost lots of money and time.
Until now the turbo XR6 still show signs of being unreliable, god forbid what an AWD turbo would do.
https://www.sau.com.au/forums/topic/79926-awd-falcon-turbo/#findComment-1455284
There have been rumours of that for a while from both the Holden and Ford camps..
I am not sure whether I can see it happening in a production car from them because of the cost, and being able to sell. Sure it would be awesome, but whether they can get the public to bite at $60k+ not so sure.
You have to remember also, that in places like Japan they can afford to throw millions more at development for fancy things as AWD, and trying many ideas that do and don't work during development, as they know they will sell XX hundred thousand rexes/liberties/evo's worldwide. Whereas in Australia, there just isn't that return on investment.
https://www.sau.com.au/forums/topic/79926-awd-falcon-turbo/#findComment-1455963
BTW, the Nizpro Territory ran a 11.7 on the 1/4 recently
Yep a couple of records were broken that night, 11.7 for Territory:
http://www.fordxr6turbo.com/forum/index.ph...showtopic=18714
and 10.56 for an XR6T sedan.
http://www.fordxr6turbo.com/forum/index.ph...showtopic=18713
https://www.sau.com.au/forums/topic/79926-awd-falcon-turbo/#findComment-1457935
Yeah, it might be a Ford, but it is also brand new and has a factory warranty.
While it is no GTR or Skyline, you guys are gonna want something that is a six cyl turbo in the near future and I bet a XR6T will be the top of the shopping list, I was so impressed I bought one.
$1500 in mods and I have a 12sec car that can carry 5 adults and their luggage:whatsthat
https://www.sau.com.au/forums/topic/79926-awd-falcon-turbo/#findComment-1458162
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
