  • Replies 40
ahh yes Troy, but in this pic you can clearly see it's a tomei boost controler: :P
BTW the oil pressure is not particularly good. with oil temp below 30 degrees C I'd be expecting oil pressure to be up and above 6 bar at idle.
Also considering that there is no System Head-Unit visible, and theres an amp.........where would it be? In the dash?
Possibly in the glove box or mounted behind and to the side of the driver somehow. Since there's no rear seat there are a number of things that could be done given the extra space.
Good spot:)....so whats the hose coming out of the master cylinder:confused:
If you mean the 'pipe' that appears to come from underneath the reservoir and loop back behind it, then that's the lead for the reservoir level sensor......mine has that.
Arent they a little 2 pin lug and wire though? That looks to be a hydraulic fitting and hose of some description...dunno, its probably nothing out of th eordinary:)
You bought a GTR and you dont know what a numberplate bracket is! ncie one :D
LoL its obvious when you concentrate.......I posted those pics at like 1.30am last night....there, that's my excuse ;)
hmm, there are a few things I don't like about it, but they can be fixed :D
-The hand brake raises up way too high as Ronin said
-Roll Cage and Gauges usually/definately means it was a race car
-Dusty engine bay...has it been parked for a while?
whats the kays on the clock?
also it has a white dash, is that a 320 kit?, nice if it is
looks wikid in red
Yeah engine bay does look dusty, hand brake is def. poorly adjusted, maybe the bolt that holds it in place is loose? Yeah, def. has been raced, then again, so have a LOT of GTRs, especially the 89/90 ones that have come in......will probably need a bit of dosh to fix up some small bits n pieces.......i'm used to that though, as is the norm with GTR ownership.
Meanwhile we're on the topic of GTRs being raced, I think my current one was raced as well, it came with a fancy belt mechanism, and some E (exit?) sticker lol.....hmmmm just thinking out aloud. Anyway, heres a pic that has both the racing belt and the E sticker for those who are interested!
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
