  • 6 months later...
  • Replies 82
Hey all,
Just installed my SITC last night. Just wanting to make sure everything is working ok. When I just switch the ignition to on (not start car though) the lights do a little dance and then go Red. Kick the car over then the first one is Green, Second is orange and the last 3 a Red. Is that normal or should they all be green. I used a timing light and tried the 800rpm knob from 10 degrees retard to advance and thats what it showed on the crank when look at it with the light. So i assume that since this knob is working the rest will too.
Thank for any help
Josh
yes that is correct. You should be able to hear the difference in timing at 800rpm going from -15 to +15.
The unit also tracks what revs you are at. For example if you are at 4000 rpm the 4000 rpm light will be green, the 5600 and 2400 will be orange and the rest will be red.
Im a bit gutted it doesnt have an adjustment point for 4600 rpm as thats where the ECU R&R really cuts out.
Yeah sweet. I was only testing it at idle but could hear the revs change when retarding and advancing the 800 knob. And I double checked it with the timing light. Now just have to get it and the safc tuned. I have both units set at zero correction and after fitting the front mount I have raised boost to 10psi and man is it running like sh#t. From about 3000 the ecu is really retarding the timing and then kicks back in again around 4800 to 5000. Light throttle normal driving is ok but when I go wot the map feels like its all over the place not to mention worse fuel economy then I was getting before so I'm assuming I'm hitting R&R. The car has previously made 150awkw with the previous owner but no piggy backs so am hoping for at least that again. However I'm guessing its had a few piggy backs in its life going but the amount of tapped wires on the ecu loom :stupid:
  • 2 months later...
Hi,
Just wondering if anyone can give me an idea of what sort of adjustment settings I should expect to be needing with my S-ITC. I am not planning on doing this myself, car is going on a dyno, but wanted to have an idea to tell the tuner where to start and to compare what he comes up with. I also have a S-AFC neo going in at the same time.
Car:
97 Stagea RS4
Mods are:
*BOS Split front dump pipe
*CATCO Metal Cat
*3" trust exhaust (not sure exactly what one, has two oval mufflers though - from R32 and modded to fit)
*Turbotech mechanical boost controller (These are gated, so actually hold pressure to specified Psi, doesn't just bleed air off constantly. Pretty sweet for $30)
*R34 Skyline Intercooler
*K&N panel filter
*radiator air deflector :D
Planning to be running 9-10Psi boost, depending on what the air temps with just a sidemount cooler look like.
Thanks,
Stu
You'll be fine with 11psi.
I'll get some info on my settings tonight (or try a search on: Tangles SITC settings, Tangles SAFC settings).
edit: here we go http://www.skylinesaustralia.com/forums/in...hl=Tangles+SITC
thanks guys,
looking to get it all done in the next few weeks so will let you know the power figures and settings for comparison. Also have a GTR fuel pump going in, to be on the safe side :(
Where can i get a SITC from? i am having trouble finding it...
here's one for you :w00t:
http://cgi.ebay.com/ebaymotors/JDM-NEW-NEW...sspagenameZWDVW
Just keep an eye on eBay (US site www.ebay.com) as they pop up pretty regularly. 'Used' ones are usually $199. I got mine of this seller in 4 days.
  • 10 months later...
Got my Apexi SITC from Japan though ebay. The instructions are in Japanese but there is a translation somewhere on the internet. If anyone needs it I have the PDF pages for the Stagea. will attempt to attach them but if that doesn't work I can email them.
I would love a copy of these while I can! There are no other alternatives to the S-ITC that I can find (like jaycar iebc / apexi safc are alternatives) so I will probably need to get one of these one day. Can you have a go at posting it here first so we can all benefit, or else PM it to me? Cheers :)
guys try this link:
http://www.ca.dsm.org/tech-sitc.html
do you need me to scan the stagea wire diagram?
its here on the site: http://www.ca.dsm.org/Tech/S-ITC-p.10-11.pdf
*grabbed* awesome, thanks Tangles! Do you know if this suits series 2/R34 as well as series 1?
yeah dowloand the pages for setting up, installing etc, and the stagea / skyline pages
you and/or your mech and his auto electrician will be able to do the job for cheap.
she'll work, she'll work
:rofl:
heads up guys
nother one on ebay US
http://cgi.ebay.com/ebaymotors/Apex-i-Supe...1QQcmdZViewItem
179.95 US
Sh!t, missed it!! thanks for the heads up though
:P
Edited by DaveB
If I've the chance to get a apexi sitc should I go for it??
Car sits as follows, downpipe, decat, hks exhaust, uprated hybrid turbo, uprated fuel pump, apexi airfilter, uprated coil pack, greddy fmic, greddy boost control.
Yes definatley as although they do come up they're still not easy to get. But get a Apexi SAFC while your at it. That way you'll be able to tune Fuel and Timing. Also when you do make changes on the SAFC it can have an effect on the timing also which can be dialed out with the SITC.
Cheers for the fast reply mate! I got one second hand still in box and in good condition ;)
just looking for a well priced safc now! :)
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
