my 32 is that black bit of dust in your 9th pic wilch  :wavey: lol rukus very nice mate.
bit of dust?
the one in the front.. twas sexy! The drivers side rear looked like it was sinking in the mud though!!!
  • Replies 393
we didn't pre-enter due to the fact we didn't know if we were going to make it.....but judging should have commenced as soon as the first car was parked and ready to be looked at (my 2 cents)
Yah, but the majority of people there *could* have pre-entered if they just got off their collective asses earlier :bonk:
Starting the judging as soon as the first car was parked would have consisted of starting the judging at 7:30am ;)
Basically, I arrived at 8:30am (when we advertised that we would start taking entries) and there were already about 20 cars processed and parked in the field... WTF?!?!?! :chairshot
I then had to go through 100 entry forms, entering in the details of each car into our judging database. Even with Nick's help, this took about a minute per car. Then we needed to print off all the judging sheets, which took another 30 mins or so...
Then we had to find all the judges (surprisingly enough, they weren't as keen to get there at 4am like Wilch and Silver-GTSt were :D ) and brief them on the judging criteria and how to fill out the judging sheets.
Judging itself took about 3 hours, and then we needed to collate all the forms, and enter the results for each car, times 6 judges, for upto 4 catergories... This took about an hour.
Grouping the cars into make and model was one suggestion made (e.g. Grouping all the R31s at one end and all the R34 GTRs at the other end). Although this would speed up the judging IMMENSELY, it would see a very biased spread of spectators methinks... Some cars will get a much reduced walk-through rate if we segregated the field like this. I don't think this is a good idea.
If anyone has any other suggestions on how we could make this process faster, it would be much appreciated, as we (the organisers) would like to reduce the time taken to judge the cars as much as you guys do!!! :uh-huh:
I think all the judges/organisers should own skylines :D
*runs and hides behind a rock........
merli I take it you didnt get a chance to take any pics then ??
shame cause your photos from last years were awesome.....
merli was taking heaps of photos
post em up!
spit spot!
Skylines are so 1995 :D
I went around and took a few shots, but nowhere NEAR enough as I would have liked... Also, I forgot to recharge the batteries in my flash, so I'm not expecting any decent shots ;) I'll go through them soon...
that silver one isnt mine. that's silver-gtst's silver gtst :D
this one is mine:
http://www.we-todd-did-racing.com/wetoddim...GZkMzF5NTQx.jpg
rukus i know your's was the blue gtst!!!!! the won that's a daily driver hehehe. no wilch im the black r32 with GRUNTN plate's
This one was my absolute fave - the dish on those rear rims was HAWT. very tight car.
and my girlfriend liked this one the mostest:
hope the pix work
did anyone else notice that 33 has been resprayed the same colour as toyota echo's and camry?
Did ya get any of the Green boat by any chance??????
Nope, it would have cracked my lens!!! ;)
Mate, seriously... Thanks SOOOOOOO much for spinning the decks all day... The music and PA system brought the show onto a whole new level, and added great ambience to the day.
You're a fcuking legend :D
Manu, you came 2nd place on points... Beautiful car mate!
Just went through my pics...
Waaaaaay too contrasty :D It was useless trying to take pics yesterday without a flash ;)
I'll post some up anyway when I get a chance.
Congrats on a wonderful day!
Good to see new faces and catch up with some of the old.
Toulia, thanks so much for the bread rolls mate!
You have to come to more SAU events though!!! Just cos you don't have your GTR anymore, doesn't mean you're allowed to leave us! :D Just look at me, I'm sticking around like a bad smell :uh-huh: :uh-huh: :innocent:
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
