dd4321 Posted July 22, 2005 Share Posted July 22, 2005 What's the odometer reading on your R33 GTST Skyline? Apologies to non R33 GTST owners. Thanks DD Link to comment https://www.sau.com.au/forums/topic/81485-how-many-kms-has-your-r33-travelled/ Share on other sites More sharing options...
performance-wise Posted July 22, 2005 Share Posted July 22, 2005 my odometer only reads 9100 cos I replaced it with a nismo cluster It has done just over 100K though Link to comment https://www.sau.com.au/forums/topic/81485-how-many-kms-has-your-r33-travelled/#findComment-1479819 Share on other sites More sharing options...
Jimbo2000 Posted July 23, 2005 Share Posted July 23, 2005 109000 Link to comment https://www.sau.com.au/forums/topic/81485-how-many-kms-has-your-r33-travelled/#findComment-1480029 Share on other sites More sharing options...
MANWHORE Posted July 23, 2005 Share Posted July 23, 2005 64 Link to comment https://www.sau.com.au/forums/topic/81485-how-many-kms-has-your-r33-travelled/#findComment-1480040 Share on other sites More sharing options...
gtrGhosTDoGG11 Posted July 23, 2005 Share Posted July 23, 2005 I wonder whats the highest a GTST has run without needing an engine rebuild. One that has been looked after. Hopefully there is one with 300,000 kms =p But there probably is, because most of them are wound back in Japan hence, we might be sitting on 200,000 instead. Link to comment https://www.sau.com.au/forums/topic/81485-how-many-kms-has-your-r33-travelled/#findComment-1480131 Share on other sites More sharing options...
IOWNU Posted July 23, 2005 Share Posted July 23, 2005 Mines on 81 thou. Link to comment https://www.sau.com.au/forums/topic/81485-how-many-kms-has-your-r33-travelled/#findComment-1480143 Share on other sites More sharing options...
elbee111 Posted July 23, 2005 Share Posted July 23, 2005 Just clicked over 153,000. Had 67,000 when we bought it. Daily driver = yes. El Bee *edit - I intend to put another 6km on it at the drags next Sunday as per last time. We did 24 runs last time without a hitch. Do oil and filter every 5000 etc though* Link to comment https://www.sau.com.au/forums/topic/81485-how-many-kms-has-your-r33-travelled/#findComment-1480184 Share on other sites More sharing options...
nathn_r33 Posted July 23, 2005 Share Posted July 23, 2005 S2 R33 75k Link to comment https://www.sau.com.au/forums/topic/81485-how-many-kms-has-your-r33-travelled/#findComment-1480300 Share on other sites More sharing options...
Sambo33 Posted July 23, 2005 Share Posted July 23, 2005 163,000, engine is being rebuilt at the moment Link to comment https://www.sau.com.au/forums/topic/81485-how-many-kms-has-your-r33-travelled/#findComment-1480346 Share on other sites More sharing options...
Paradizzle Posted July 23, 2005 Share Posted July 23, 2005 how much for the rebuild? Link to comment https://www.sau.com.au/forums/topic/81485-how-many-kms-has-your-r33-travelled/#findComment-1480359 Share on other sites More sharing options...
Sambo33 Posted July 23, 2005 Share Posted July 23, 2005 how much for the rebuild? full bottom end rebuild with forged pistons ect, plus reco of the head, will be somewhere in between $5-6K, depends on the extent of work to be done Link to comment https://www.sau.com.au/forums/topic/81485-how-many-kms-has-your-r33-travelled/#findComment-1480397 Share on other sites More sharing options...
Wink Posted July 23, 2005 Share Posted July 23, 2005 66000 Link to comment https://www.sau.com.au/forums/topic/81485-how-many-kms-has-your-r33-travelled/#findComment-1480404 Share on other sites More sharing options...
**JaR** Posted July 24, 2005 Share Posted July 24, 2005 61000 Link to comment https://www.sau.com.au/forums/topic/81485-how-many-kms-has-your-r33-travelled/#findComment-1481124 Share on other sites More sharing options...
benl1981 Posted July 24, 2005 Share Posted July 24, 2005 93 GTST 100k kms Hey Sambo - Did your motor give up or just upgrade time? Link to comment https://www.sau.com.au/forums/topic/81485-how-many-kms-has-your-r33-travelled/#findComment-1481145 Share on other sites More sharing options...
nzm033 Posted July 24, 2005 Share Posted July 24, 2005 93 GTS-T 93000 kms.......pretty hard to believe for its age Link to comment https://www.sau.com.au/forums/topic/81485-how-many-kms-has-your-r33-travelled/#findComment-1481192 Share on other sites More sharing options...
Links Posted July 24, 2005 Share Posted July 24, 2005 ~70,400 - 98 R33 gts-t.. Link to comment https://www.sau.com.au/forums/topic/81485-how-many-kms-has-your-r33-travelled/#findComment-1481194 Share on other sites More sharing options...
Sambo33 Posted July 24, 2005 Share Posted July 24, 2005 Hey Sambo - Did your motor give up or just upgrade time? engine gave up mate. it started drinking about 1L of oil every 1000ks, it turns out the ringlands were stuffed on all 6 pistons. Link to comment https://www.sau.com.au/forums/topic/81485-how-many-kms-has-your-r33-travelled/#findComment-1481199 Share on other sites More sharing options...
rinmak Posted July 24, 2005 Share Posted July 24, 2005 115,000 and going strong! Link to comment https://www.sau.com.au/forums/topic/81485-how-many-kms-has-your-r33-travelled/#findComment-1481216 Share on other sites More sharing options...
benl1981 Posted July 24, 2005 Share Posted July 24, 2005 Sambo - that was unfortunate , from when you go the car was it like that? Did it blow a bit of smoke. Mine doesn't use anything in 6000kms so I guess mine is ok ... Link to comment https://www.sau.com.au/forums/topic/81485-how-many-kms-has-your-r33-travelled/#findComment-1481219 Share on other sites More sharing options...
Sambo33 Posted July 24, 2005 Share Posted July 24, 2005 Sambo - that was unfortunate , from when you go the car was it like that? Did it blow a bit of smoke. Mine doesn't use anything in 6000kms so I guess mine is ok ... the problem came with the car, it just gradually got worse in the last 5000ks, i really should have been more thorough when inspecting the mechanical areas. yep it blew loads of smoke at high rpm, also under serious loads i could fill an 800ml catch-can up in about 60 seconds. oh well... now i can do some track/drag days without worrying about my engine spitting it Link to comment https://www.sau.com.au/forums/topic/81485-how-many-kms-has-your-r33-travelled/#findComment-1481238 Share on other sites More sharing options...
