z32 brakes are the same as R32 gtst brakes, depending on the series. they are a 4 pot caliper but run on a smaller 280ish mm rotor. i'm sure you could get them to bolt up, most of the calipers share the same mounting hole centers, but i dont think they would be much of an upgrade. best go for some R32 GTR/R33 GTST brakes, or even better R34 GTT's
Ah, cheers for the info. Had a chance at buying a fairly cheap set of calipers, but that fell through anyway
Hey guys.
I'm racking my brain trying to go through this topic cause new info keeps contradicting old info.
I'm a little on the simple side when it comes to this still
I have DBA4908SL/R rotors for the rear of my S2.
I'm under the impression they need to be machined by 5mm OD.
Is this correct?
If they have to be machined is there any other rotor that will be a direct fit?
I'm also assuming that DB1399 is the right pads?
Can someone confirm this with me please?
Trying to get my car back on the road this week.
Cheers Jason
You're right - its a dogs breakfast. I would like to see a spreadsheet with the first column headed "Stagea model" e.g. S1 awd, S1 rwd, S1 260 RS, S2 awd, S2 rwd, S2 260Rs, M35 etc etc and then subsequent column headings such as Front rotors, DBA###(say three types: stock, heat treated, heat treated and slotted) Rear rotors..ditto. Front pads Bendix###, Endless### etc, Rearpads ditto, handbrake shoes ### and columns for alternative brakes e.g. R34GTT brakes, R32 GTR brakes, R33GTR brakes, R34 GTR brakes you get the picture. Then in each cell of the table : verified by 3 members, or 6 members or "will NOT fit verified by..." or "can be made to fit with inexpensive modifcations" !!
I don't know if this would need a moderator to be able to make it work but it would have to be somewhere where it wouldn't get lost and people would have to be reminded to contribute their real world (yes I've done it and it works/doesn't work) experience (not "my cousin's mechanic says it will fit") .
Does this sound too ambitious/too much work? I have read the sticky and various threads on brakes and there is some contradictory "information" and people pop up asking the same questions without necessarily getting a correct answer!!
I've been quoted $100 to get both rotors machined down to the diameter of my original rotors.
I only paid $102 each for the 4000s so I can't complain.
Only problem being I was sent the wrong pads because they said they took same as a skyline.
I now have $300 worth of brake pads that will help in no way shape or form.
Ah well will just hock them off on here.
Will post back up how my rotors go, will be done tomorrow or thurs.
quick question - S2 stagea RS4, putting R33 calipers on. in regards to the brake lines if i buy a kit for stainless lines they will bolt on the calipers itself but does anyone know if they have the same connection on the other end? thanks in advance
yeah it will be the same. i've trail fitted R32 GTST braided brake lines to mine to see if the fitting were the same and they were. just when you fit braided brake lines you omit a couple of junction boxes that the factory brake lines run between. but yeah the fittings are all the same.
this is what I have now I think on the front, standard rears
needed new rims and some drilling and clearance is just sooo fine of caliper to the rim barely more than a mm but looking and feeling good
what size wheels are you running on your car? did you ever have the stock wheels on with these brakes? and if yes, did you use a spacer etc? thanks!
ok the rear brakes all sorted.. i had to trim the back plate a tad, the rotors fitted perfect, the only other things i had to do is put a small washer between the hub and caliper to space it out a tad and the original lines didn't quite reach so i just screwed it in our of the holder. see the pics, everything else just fitted and worked... yah
Hi all,
Just to let everyone know we've recently imported a few sets of S2 Stagea front pads in Remsa. Remsa are a 650 degree European made pad (so 100 degrees better than Bendix Ultimate), and a very good heavy duty street pad.
Price on the S2 Fronts is $95 per set including shipped. Also, for those people who have inquired or on back order for Stagea pads in QFM materials, we're about to receive our first batch of backing plates, so will have both HPX ($110) and A1RM ($149) available soon.
Regards,
Greg
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
