been doing a bit of searching, but haven't come up with many answers, so i'd thought i'd ask you guys.
R34 GTT front brake upgrade... how much have you guys paid? So this would be calipers and rotors. Looking at my upgrade options, but really not sure what i could get for my stock front rotors/calipers and my stock rear rotors.
cheers,
daniel
cheers,
daniel
Don't know if this helps but I just got a set of R34 GTT front brakes - 4 pot calipers, 310mm rotors and a set of little used pads for NZ$295 delivered. I expect to get between $0 and $30 for my old ones. [Just as an aside i would guess by picking up the box of bits that i have just added back the unsprung weight that I lost by getting light weight rims!]
Hey just wondering does anybody know the minimum thickness of series 2 front and rear rotors?
Well the R34 GTT ones have it cast in raised letters (min thickness 28mm) so maybe the S2 ones do as well.
that seems awfully cheap
cheers,
daniel
I paid $800 for a full set R34 GTT brakes, front and rear.
Included the brake booster, brake lines, bolts, pads, rotors and calipers etc.
It was 2 years ago. Prices were a little higher back then.
I just bought a set of R33 front and rears calipers with slotted RDA rotors and fancy pads, all done 5-10000k's for $550.
server problems, data lost
pm -RBD2- if you are after old s1 pads
thankyou, will do.
THEN MAY BE POST IN RIGHT SECTION LIKE [WANTED] LIKE MOST WILL DO
i say sorry sir. i appologise. please dont yell at me. seemed like an appropriate place to me.
I managed to find a set of GTT rear calipers to go with my fronts but had no rotors. Got brand new rear rotors for $80 a pair so I guess fronts would be not much more. If you are paying much more in Aus then let me know if anyone wants a set mailed over ( the postage would not be worth it for a few dollars difference but if you are paying over $100 ea for GTT rotors you may want to consider importing some from here!
**Acre Super Fighter Pads now available for Nissan Stagea Series 2 fronts!!! $95 delivered!!!**
All the details at Skylines Australia Traders Section!
For those hanging out for the QFM pads, both HPX and A1RM should be ready in about 4 weeks! Rears, and series 1 pads under development.
Regards,
Greg
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
