Whatever you reckon. Rotor size (ie. the thermal mass and it's ability to dispense the heat) is what's important. Pad size accounts for 3/4 SFA. But uno, you're the expert, what ever helps you sleep at night. The laws of physics are broken all the time...
  • Like 2
If you read i put N1 brake ducts on my car THIS IS A MISSIVE HELP :thumbsup: so i guess your not reading what iam done with my car :whistling: ,
Iam not some silly kid that your talking to ,
But I guess you have a Stagea :no:
I do try different stuff with my BRAKE SETUP,
as you see i did have my Backing plates REBONED & have had R32 4 pots on my car ,
BUT again i don`t look at my car as a Performace car like many think they are ,
I have looked at many ways to IMPROVE STOCK SETUP,best i can do on a small budget,
:wave:
cheers chuckie. might i say those braided lines look the business, i guess the rubber lines would have done the job for the first 10 yrs of the cars life but id imagine mine are fairly well toast by now.
i think i might save my coin and get GTT calipers with braided lines and some dba/rda slotted rotors and EBC greenstuff pads cos ive had a good run with them and they arent anywhere near as dusty as some.
if i end up turfing my SMIC you rekon it would be worth running some ducting from the front bar ends to the brake calipers/rotors? just something home job nothing to overboard.
Or you can generally pick up 2nd hand brembos for like $1500 of a 350z
thats the line i was enquiring about, im aware alot of people are running the 350z rotors but will 350z brembos only bolt up to m35's?
Just wanted to say i have just done the rear pads on my RSFOUR-S and they are definitely the Bendix DB1399.
If your old pads still have the metal backing shim plates to help spread the piston load across the pad, then you will find that the 2 little nipples on the back face of the outer pads will interfere.
Use some side cutters to remove the nipples and file them back to be flush. Apart from that, perfect fit.
Jez
Guess this is the best place for the following.
Just did a skim and rear brake pad replacement on my M35 300RX. All went well and feels perfect now.
The pads where a stocked off the shelf item and where listed for the M35.
They are Bendix DB1509 GCT and are a perfect fit. Cheap at only $80 total for both sets.
They are the ceramic tech ones with titanium stripe (no bedding in).
The fronts were changed earlier and are the Bendix DB1232 GCT.
Too easy!
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
