Im looking at the non Akebonos, so I assume they are the touring?
From the pic the calliper mount bolts look a long way apart. Is this what Spoolin needed the adaptors for?
If they r off a z33 then they should bolt up. I didnt know z34 came in anything but 4 pot akebonos...
These are from a Z34. So then maybe they won't fit then without an adaptor, its not worth the trouble of an adaptor for these brakes IMO.
I think the later Z33 came with a 2 piston single sided calliper but I can't seem to find them anywhere pinch.gif
These seem to be the only option I now have apart from slotted rotors and GSR pads for the stock M35 brakes.
Who has done slotted rotors and GSR pads for stock M35 and found the results?
Edited by slippylotion
Both Aaron and bigkev are running slotted rotors with hpx pad I think...
There are a lot of people on here, which is why I figured I'd start with that and see how I go.
I haven't fitted mine, still waiting for everything to turn up, but my setup will be:
DBA4000 Clubspec T3 rotors
QFM HPX pads
StopTech braided lines
Motul RBF600 brake fluid
The above kit is a nice bit of gear
Ive been looking at getting a set for my stagea.
If anyone is keen they are pretty damn cheap from the states.
They can be bought for under 1k delivered
Akebono Kit
With such massive brakes on the front end, surely your bias would be a bit off.
Well I got the 33GTST fronts today to fit to the 25G. They are 295 X 30, 2 pot. So they should pull up the Stag when the turbo is fitted.Still sourceing rear sway bar, its RWD, and front strut brace.
Actually they are 4 pot, so they are going on the RS4. Will see how the stock RS4 fit on the 25G.
I'm looking at upgrading my brake rotors on my Series 2 RS4-S. I want to put front & rear slotted rotors in with some decent pads. I'm keeping the stock calipers as I only use my car as a daily.
What brands/part numbers etc do you recommend oh gurus?
And if anyone could tell me the diameter I need too that would be a bonus.
Cheers!!
Cheers!!
Search or read what many have put here :whistling:
as this has been covered many a time :thumbsup:
Pads are dead simple, I'd go Remsa in the front, which is what we supply as a trade servicing pad for high end Euro sports cars like Porsche, Ferrari etc and are rated to 650 degrees (versus 550 for something like Bendix Ultimate or QFM HPX), and QFM Super X in the rear. Remsa to suit front are $105 for the set, and Super X rears are $49.
Dixcel have direct replacement rotors for our cars (either standard or slotted)...but there are no distributors in Australia. This is according to Dixcel in Japan when I emailed them and ask about who is the distributor in Australia
As previously mentioned in here that you can get DBA rotors and machine the OD to match and fit the standard rotors (unless you've upgraded to R33/R34 rotors and callipers or you own a M35)
I'm looking for a set of Dixcel's locally but it's hard to find them and importing them in is expensive (due to the weight for shipping).
Whilst people in the know have ensured me that machining the OD of the disc is perfectly safe...IMO I don't want to chance it
    • I used to have Walbro 255's when they were a pretty common update. (or were they 044? 040?) In any case I had a dirty tank. I thought the tank was good, but I would find the filter would clog in maybe ~50km of driving. If the issue persists, well, your fuel system or tank has crap in it that the pump is sucking up.
    • Hi. Ok thanks for the info. I/we do not know what tune is on that Nistune ECU so it is why there is stock ECU and that Nistune is for later when the car is done. I have guy who tunes Nistune and other ECU so i will then take it to him to see and properly tune for the car   And for the update. On 99,9% it is bad fuel pump. Which is wierd cuz it is like 2 years old(brand new walbro 255) and that filter (also brand new) was dirty.  I was alwaya pumped premium(100) on very good petrol station so i dont know how is that possible...
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
