Hey fellas,
I'm seriously thinking of buying my mates rb25 with lots of work done to it and removing my rb20 out of r32 manual gts-t and has anyone done this before and was it a prick of a thing to do or was it straight in? Apparently if i keep my r32 gearbox in my car with a rb25 it wont work cause of some shaft that is too big on my gearbox but if i use his gearbox which is series 2 r33 box it will be fine? What do u ppl reckon all comments and tips needed,
Thanks Mike
https://www.sau.com.au/forums/topic/82183-r32gts-t-with-rb20-maybe-to-be-rb25/
i had an R32/HR31 gearbox bolted to the back of my RB25.
only recently put an RB25 box in behind the RB25 motor.
notice much difference with the rb25 box?
im still running the rb20 box behind the rb25 in my r32 :cheers:
with the price of gearboxes these days i was thinking i will probably just replace it with another rb20 box if this one dies.
seems to be going strong though...
i figured as long as i dont put some comp slicks or something on the back then it shouldnt be too bad... dunno :)
hows yours?
I did the conversion but i never had the 20 box behind the rb25 so i cant really say what the diff is however on the whole i strongly recommend conversion. Mod plates in qld are cheap as chips to get to. One question i have that i dont feel has been answered in previous discussions, of all the people that have done this conversion what have you done with your diff? eg. keep 20, replace with 25, strengthen rebuild of 20??? After about 3 months of solid driving and a night out at willowbank 1/4 mile mine is starting to slowly slip which my heavy duty clutch isnt a huge fan of and i want to get it sorted. Should I get strong rebuild of 20 (ive heard good things) or go the 25 swap?? keep in mind it was originally non turbo (4 stud)
the gearstick sits about 5cm higher.
thats the only difference.
My RB20 box wasnt stuffed. It just got the death whine about it.
So i upgraded before it died rather than afterwards.
I did this conversion on a GTS4. The RB25DET drops straight in and the gearbox bolts straight up onto the engine.
Next step is to fit a 4.08 diff set to replace the stock 4.375 - RB25DET just has too much torque for the current ratios.
diff stength I've heard is quite similar.. in fact the R32 clutch based diff one may be stronger than the viscous diff on the later R33 (edit: ok, maybe thats not correct). If you have an LSD, it should be the same as the one fitted to the turbo model. Depending on the cost, vs finding another one, I'd get your existing one rebuilt.
I thought only the32 GTR had a clutch type, gtst still has a viscous
On a side note, i've also done the swap and it is great. Same turbo and i now have full boost at 2800 rather than 4200 :cheers: Also have an extra 25 kw at the same boost with a shitty home tune on the emanage, though i now have a pfc in it and it feels alot stronger with even more midrange punch.
Retained the rb20 box, retained the rb20 diff (but that was already dying). It's next on the list of replacements.
  • 1 month later...
What final plans have you got for the rb25det?
If its to head upwards of 300rwkw why not simply grab a R32 RB25DE, slap a set of forged pistons in it and be done with it.
The PowerFC will run fine on the r32 rb25de, afterall, thats exactly what I have done with the only difference being I slapped a rb30 block underneath the rb25 head.
The reason I say to go forged pistons is the N/A blocks don't run piston oil squirters. :D
The only issue that may exist is the emissions side of things as you will be obviously using an aftermarket ecu, that obviously doesn't bother you though. ;)
It will still run on the rb20det ecu, simply throw an R33 wastegate actuator to limit boost to 6-7psi. 6-7psi is on the limit of the rb20det's ecu fuel cut once you are running the much better flowing rb25 head.
Edited by Cubes
you rb30 pusher you..
or slap in a perfectly good rb25 bolted together.. loom, etc. Nothing to worry about drilling blocks, speaking to engine builders, etc. Good for a nice 230-250rwkw with revability. If it blows, you have all the required parts ready to go for rb30 later on.. :D
i run an ap engineering power fc on my rb20det, will this work on the rb25det, and can you use the same loom.
rb20det doesnt run VCT, rb25det runs VCT (edit: oops).. you would have to disable the VCT via playing with the engine and dick around... spoils the point of the drop in approach.
I can think of quite a few parts also that are different between rb25 and rb20 looms that would cause you problems with rb20 loom: cas, ignitor, injectors. But maybe its possible.
Edited by predator
heheh
I said to run a R32 RB25DE and slap a set of forged pistons in it. :D
No wiring mods, it really is a simple drop in bolt turbo manifold up, connect up inlet piping start and drive away on the stock ecu, providing you don't dial in more than 6-7psi. :cheers:
Its static compression is an issue at 10:1 or there abouts, another reason for the forged pistons or any aftermarket piston.
No pushing rb30 here :D
Edited by Cubes
rb20det doesnt run VVT, rb25det runs vvt.. you would have to disable the vvt via playing with the engine and dick around... spoils the point of the drop in approach.
Only later model RB25DETs run VVT. You can simply add in the wiring for the VVT solenoid. This is the advice I was given AFTER I had wired a whole new loom into my RB25DET -> (R32) GTS4 conversion.
I think there are other threads that suggest you simply swap over the RB20 sensors into the RB25, and everything works OK. Although I was running a RB25 CAS on my RB20, and it seemed to run OK.
Its only the rb25de's from the R32's that don't run the vct. All R33 motors (apart from rb26) run the VCT.
You can't simply add the VCT wiring and be done with it as the r33 rb25det ecu pin out is different. It has a few extra little bits plus a different arrangement. Allthough not a major drama, its easy enough to swap a few pins around.
I've checked out ecu pin outs in the engine manuals. If only it was so easy. :cheers:
Edited by Cubes
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
