Well finally i bit the bullet and bought some Toyo Proxies RA1. These are a race tyre but are street legal similiar to the Bridgestone RE55. Im not expecting a very long life out of them but when you spend a fair bit of time spinning wheels, these are a huge releif. With the old Sumitunos HRZ 11's 255/40/17, 2nd gear wheel spin was at will as soon as boost hit. Good for showing off but not good for winning races. Now with these RA1's, i have 1st gear traction on the street and it is a rocket, no more hiding at traffic lights. Just for the record, i know RWD cars doing 1.6 60's with these tyres. Im not expecting 1.6, but if i can get 1.7/1.8 60's look out for a very low 12 and then i can drive it home. Perfecto.
https://www.sau.com.au/forums/topic/82245-traction-like-a-gtr-from-a-gtst/
The drag spec Nitto's is what you want for straight line.
They handle quite well also.
Whatsisname had them on his car when it was making some where from 260-290rwkw and ran a low 12 with his granny shifting. :P
I remember him telling me he can get almost all the power from first down and second also.
Where do you buy Nittos from? and how much are they roughly?
I just found this on Toyo's website:
The Proxes RA1 has the same construction & tread compound as the Nitto NT555R Extreme Drag Radial, and therefore provides very similar performance.
Don't know if I believe it but interesting... anyone know the price diff?
If Toyo's RA1 (which they advertise as a clubsport circuit racing tyre) has the same construction and tread compound as Nitto's NT555R (which is reknown as a drag tyre), then one of them is going to suck at their advertised function.
Drag tyres make shit circuit tyres, because of their weak sidewalls. And vice versa.
With the rubber compound and tread pattern, I don't doubt that the circuit tyre will provide good grip compared to your regular street tyre off the line, but its still not ideal.
Refer to my original post, I know guys using these tyres at the drags and producing awesome launches. As for me, my car now bites hard.
If they cant do both (drag and cornering) why do alot of quick street cars use RE55's and also Ben from RacePace uses these on his track GTR.
The Toyo's are a great "cold start" tyre. On the track they are awesome for the first 2-3 laps. From that point on they go off like "Mums pants on Father's Day". Excellent hill climb tyre and for street -the only thing to look out for would be to make sure they are not overworked too much. A lot of high speed continuous cornering would see them go off. Once they do, they become very "squidgy".
Good tyre though - except they will probably wear fairly quickly.
So far i have noticed, i can still get wheelspin in 2nd when they are cold, but once they warm up, grip is phenominal. Im yet to try them down the 1/4 as yet but im predicting a nice drop in my times. I dont track race so i can't adivse you, but i only have them on the back so i would be understeering quite badly.
So which tyres are good for track days?
Those bloody A032Rs....did you guys run the 48s? I am interested to see if they will be any better....I am hoping Gordon will be out of stock of the 32s when I need to buy the next set :P
Pete and Terry were having a tricky time with the 48s apparently?
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
