Joey, there's a joint in Moorebank called "Flame Coatings" that do industrial stuff, I spoke to them and they can do car parts, you just need to take it to them so they can see it to quote.
Might be worth a look.
  • 3 weeks later...
Gave them a bell Mark, they quoted me around $500 for 1.5m of 4 inch dump, exhaust Manifold and turbine housing..seems fair
That's without doing the gate pipes, I don't think there's any real gains to be had by doing the gate pipes as I don't think there will be any sort of restriction to flow there.
Thoughts?
I would wrap them for the heat, I would coat and wrap everything anyway as I feel that the lower the engine compartment temps the better.
As long as the bits are not stainless.
Have you fixed yours yet?
The 5 might get to stretch it legs soon as I'm hoping to do Huntley on 01 Feb.
Picking the engine up soon :)
The dump and pipes are stainless, am I missing something here?? Should I not do them?
That's mad, you will have to tell me how you go.. If love to do that hill climb eventually :D
Due to its metallurgy stainless tends to work harden and crack, dependant on its quality and engineering.
This usually will only happen where the heat is most extreme and there's some form of engineering issue like tight bends, seams or if it is bearing weight.
The coatings should be fine but I wouldn't wrap stainless.
I've had 2 stainless manifolds in my time and about 20 steel, only 2 have cracked, and they weren't the steel ones.
The initial one I got for the old boat lasted 1 track day before it cracked at the turbo mounting plate, I had it fixed and then it cracked along the pipe of one of the runners.
That's when I had that pretty steam pipe one made up through unigroup, that never had a issue and glowed like the fires of hell on lots of occasions.
Plus steel is cheap and lasts for years anyway.
Do you the the feeling I don't like stainless exhaust manifolds.
Then again I may have just been unlucky and inferior materials were used???????
Definitely getting the feeling you don't like stainless haha
The manifold is a full race steam pipe manifold so that should be ok to coat along with the turbine housing
I'm gonna give the guy would built the gate pipes and dump pipe a call and see what he reckons though i shouldn't have any dramas coating them as they won't see the same temps as the manifold
Am I right in saying that??
Has anyone seen the stainless actually crack or it crack along the seam weld? I have only ever seen them crack in the welds.
Frankly depending on what manifold it is I wouldn't have a problem wrapping them as long as you put some thought into it. Every cracked manifold I have seen has been a tubular manifold with welds with no/poor/inconsistent weld penetration. Never seen a manifold made from stainless pipe (vs tube) crack. The wall thickness is the cheap insurance and reason why people have far less issues with mild steel. IMO stainless is actually superior if done right
Full race manifolds are basically a stainless steam pipe
If you compare it to a china manifold, while it might be 2.8-3.1mm thick, the way they are made vary greatly, they are mig'd then a tig is run over to make it look like its been tig'd. Penetration varies and hot spots cant be seen as they "polish" them.
I would coat the lot.
I would even coat the exhaust all the way to the rear muffler. The heat off even the cat back section increases cabin temps, if you have carpet it will start to deteriorate the carpet just in front of your passenger seat on the hump for the cat. Even if it hasn't had a cat for 10 years! If you plan to track your car or drive in Sydney on 35deg + days its a no brainer, might cost an extra $80 since they can only do the outside but will reduce radiated heat
Seen heaps of jap manifolds crack at the welds, its prob 99% of where I have seen cracks. Im not an expert on welding and can only do enough to get me by. If I had to say 1 reason, is because they are not really that thick and the weight of the turbo/gate/poorly hung exhaust cracks it or a combo of both.
I have just finished a turbo swap where I had to mod a dump pipe that was wrapped on top half only. As seen in pic it was cooked to the point of shedding layers on the inside and outside. Had to remove 3 layers before it was able to be welded.
It's mild steel Btw. I definitely wouldn't wrap anything.
I use VHT paint prior to wrapping, this negates the corrosion.
The way I see it is if wrapping/lagging is good enough for heavy plant and ships its good enough for my car.
As for the dump that corroded, was it painted prior to wrapping, and what did it cost, I would guess it wasn't painted and it would have cost about $80 for a new one to be fabricated.
I do agree that high quality stainless pipe with good engineering should out last the life of the car.
There's a BIG difference between "high quality stainless pipe" and the typical stainless tube that is used for making exhaust components. Especially those that come from ChinaBay. Most stainless grades that are specified as being used in those sorts of products are probably a long way from the adulterated crap that they actually get made from.
With respect to lagging of industrial pipework and so on....there's almost no applications in industry where something like an exhaust manifold or turbo dump would be exposed to 700-900°C gases flowing on the inside an be wrapped on the outside. We just don't do that sort of crap. If it is going to run that hot on the inside we will use refractory lining (fire bricks for the layman) of some sort to serve as the first line of protection. Refractory will serve to keep the hot gases off the metal and act as an insulator. The steel might still end up running at a surface temperature of 150 - 400°C (depending on what and where we're talking about), but at least it's not in direct contact with the hot gases.
Where (really) hot gases absolutely have to be in contact directly with the metal, then there is no way that external insulation will be used. Lagging hides mechanical failures.
thanks lads, I took it down to see Abdul from flamed coatings... seems like a really genuine guy so im gonna go ahead and use him.
Going to get the gate pipes done as well, as discussed I don't think it will make much of the way in performance gains but im really only trying to stop the radiating heat.
Sucram im just doing up to the cat for the moment, then once its running again ill get the rest of the system done. Im also getting the gate itself done (not the diapgram part) but the part where the gasses flow,once again to reduce radiating heat.
cheers for the help
Always a tough question. The big fear is that any internal coating that comes off might cause nasty damage to the turbine. Of course, it might not do any damage. What might trash a ceramic turbine might not scratch an inconel one.
I think the general concensus amongst guys who do coatings is that they'd relatively happy to coat the inside of brand new housings that haven't had a chance to be impregnated with carbon and impurities. Less happy with used housings. By the same token, that could just be paranoia and maybe there are guys out there who have coated heaps of used ones without any problem at all.
I do know that for the ceramic coatings I've looked at getting applied to industrial burner components, the first step is to make sure the (brand new 253MA or inconel) parts are scrupulously clean. Washed to within an inch of their lives. That's bright, clean shiny alloy, not old, grody cast iron.
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
