  • Replies 227
Posted Images
Ant (and anyone else)
A few of us plan on doing a special run up to Benalia the back ways on Saturday with a stop off at Buxton to try out Victoria's best burgers!
:P
Check it out.
http://www.theage.com.au/news/Epicure/Burg...8514953113.html
Anyways - it means a run through the twisties - hell we may even go the super long way through Reefton yet - but we haven't decided.
Will be leaving the SouthEast / Ferntree Gully area around midday.
We're staying on Sat night, we dont' know the way as well. Do we drive there on Sat with you?
Just come to my place West, we plan to leave at 12. If anyone needs to know my address please PM me.
I forgot, was that where i met up with you, Roy...ect for PI? Can you please send your address to me thanks. [email protected].
Where do i find the latest updates on points...arent we only counting best 4 rounds etc... if Gareth is out of the picture, then maybe the RWD class is pretty safe, and i suppose i can accpet the fact that Scotsman comes 3rd, seems fair since your quicker everywhere then me
Trying to suss out a sponsored race car from soemnone like Hertx etc, perhaps an S2000. Need a RWD car that my wheels will bolt onto , or at least has 17"rubber so i can run my semis.
Bugger, the Z4 is gone ;)
What happened to your car?
If your after a rental this isn't super expensive. Its no S2000 or elise, but its mid engined, rear wheel drive and probably has the same engine as the elise.
Or if you want to spend a little more you could get something from here. The Boxster S would be fun but probably not worth it at $500 a day.
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
