Hi Guys,
will the following volk rims fit onto the R33GTR with the brembos?
8J 18 PCD114.3 OFF45
for both front and rears? Will the front clear when turnign lock to lock and the rears will it clear the callipers? Thanks
Hi Guys,
No, u would need to run spacers. They are also a lil narrow.
9-10J OFF+12 to +30 is the range you should look for.
Skyline model = R34 GTT
Wheel diameter = 18"
Wheel width = 8.5" front, 9" rear
Wheel offset = +30 all round
Tyre size = 245/40 front, 265/35 rear
Modifications to fit = none yet, need to roll the guards, and raise it about 10mm (got coilovers)
Scrubs going over humps and up driveways when your turning the wheel.. n bottoms out over large bumps :)
quick question.
I have a set of rims Fronts : 18x9 off +25 and rear are 18x10 of+40. What size tyres size to fit these? I dont mind lipping or rolling it. Car is quilvalent to an r 33gtr with brembos.
quick question.
Its not recommended to run staggered rims on cars with Attessa (AWD). As they have a different rolling diameter, it would confuse the Attessa system
then can i put in 255s allround? Will the front able to fit the 255s?
because the rims are wider, the tyres will sit differently, ie the rear profile will be lower than the front. So u may need say a 255/35 @ the front and a 255/40 @ the rear. Speak to a tyre guy about the sizes.
But it is not an exact science, so u should run the same width /offset rims front and rear. Buy my old ones Manaray 18x9 +21 for $450 ONO lol
Some say it doesn't matter if you run different width rims as long as the rolling diameter is the same. When I did that, my attesa wouldn't work. Now I've switched to the same rim and tyre on all four corners and attesa works fine (no other changes).
235/40/18s amd 265/35/18s will have the same rolling diameter. Some manufacturer will be exactly the same and some will be off by 1mm. I dont think the attessa is sensitive enough to detect that. The manufacturers are Falkens and Maxxis.
bought some VS-XX wheels from japan to be fitted to R33 GTS-T
18 x 8.5 +26 Front
18 x 9.5 +26 Rear
I used the offset calculator with my drifttek specs
17 x 9 +35 all round
and it said they would sit 15mm out further on the rear and 3mm out further on the front. So i put 15mm spacers on the driftteks and they sat bang on with the guards....looks tuff...may need some guard lipping at the rear with 18's and a bit of stretch, does this sound right?
thanks guys.
Edited by Ryanrb25
18 x 8.5 +26 Front
18 x 9.5 +26 Rear
thanks guys.
Going from the catalog wheel specs that work provide, you have -
8.5 +26 are deep rim O disks... your going to need spacers to clear the front brakes. Possibly as big as 20mm spacers.
9.5 +26 are also deep rim O disks... *may* need spacers to clear in the back. Ive never tried to fit O disks on a R33 before.
This is going to make them harder to fit, but if your not scared of flaring and stretching tyres on it will look super hot. Can also dial some camber in to help fitment.
Edited by mr_squiggle_1
I'm getting rims from Japan
18x9 with +26 offset allround... what tyres would u recommend for the fronts and rears on R32 GTST (stock guards and rolled) also car lowered
cheers
I've got brand new 2 tyres 245/45/18 in bridgestone adrenalin RE001 but dnt know if they'll fit your rims. Happy to let them go for $550 ono. PM me if you're interested. Sold my 18 inch and got these delivered on 24/12/07. Paid $680 for 2 tyres after getting discount.
Edited by R34NOS
Will these rims sizes fit the 260rs which is equivalent to an R33GTR with brembos brakes?
Front 18×9J +25 5H
Rear 18×10J +40 5H 114.3
thanks
Will need spacers on the rear, but other wise should fit fine.
Neil
The question of what wheel size fits what Skyline comes up so often I though this might be a good place to post your own wheel dimensions.
Just copy and fill in the table;
Skyline model = R32 GTS4
Wheel diameter = 19"
Wheel width = 8" front & 9.5 rear
Wheel offset = not to sure
Tyre size = 265
the rims are konig unknown
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
