just wondering what would be needed (if anything) to make a seto of 17x9 +22 (gtr offsets) fit a r34 gt-t.
depending on ride height & camber
but for my car needed no guard work to fit.
i had 215/45 front & 235/45 rear
Skyline model: R33 GTR
Wheel type: Rays Volk Racing RE30
Wheel diameter: 18"
Wheel width: 9.5"
Wheel offset: +15
Tyre size: 265/35 18
Suspension: TEIN coilovers (lowered 1" from standard)
Modifications to fit: None
Skyline model = R32 GTR
Wheel diameter = 20" all round
Wheel width =10" all round
Wheel offset =i cant remember
Tyre size =285-30-20
Modifications to fit = and the list goes on.......lip front guards,cut out small section of factory v-spec body kit,remove inner plastic guard liner and make own ones...thats the front.the rear fit well,just a bit of masaging in the inner wells.
the car runs ISC coil overs and is dumped 3.5" all round.
im looking to get a set of 18x10 +22 front and back i know the rear will fit cos of some crazy posts ive read and my guards are lipped and pumped 8mm
but the front im not to sure can any one help.
Skyline model = R33 GTST
Wheel diameter = 18
Wheel width = 9 front and 10 rear
Wheel offset = +24 front +20 rear
Tyre size = 235/45 front 245/40
Modifications to fit = adjustable camber arms :P and lip rear guards
Wheel diameter = 18
Pics?
Skyline model =R33 GTSt
Wheel diameter =18inch
Wheel width =(F) 9inch ® 10inch
Wheel offset =(F) 35 ® 37
Tyre size =(F) 225/35 ® 235/35
Modifications to fit = None
hey dave, how low is your car?u got adj rear camber arms?
coz atm i got 18x9.5 on the back and the rim hits my coilovers when going up a driveway, going to need a 6-7mm spacer at least to fix this. this might help you get the fitment right to prevent any scrubbing :)
Skyline model =R34 GTX
Wheel width =(F) 9inch (R ) 9.5inch
Wheel offset =(F) 19 (R ) 30
Tyre size =(F) 215/40 (R ) 235/40
*i might swap the front to the back as the rears sit in by 2mm and the front sits flush on the guards.
Stock height for now, have Tein Flex coilovers going in this week.
Though my engine and drive line are not in the car yet and this will lower the car alot, so ill have to wait and see.
no worries mate, post up some pics when you get them fitted :banana:
new fitment:
Wheel width =(F) 9.5inch (R ) 9inch
Wheel offset =(F) 25 (R ) 14
Tyre size =(F) 235/40 (R ) 235/40 (gonna try 245 next)
Modifications to fit = lipped rear guards
Skyline Model = R33 GTS-t Series II
Wheel diameter = 18
Wheel width = 8.5
Wheel offset = +35
Tyre size = 235/40/18
Modifications to fit = Rolled front, lipped rear (due to previous wheel fitments)
Skyline Model = R33 GTS-t Series I.5
Wheel diameter = 18
Wheel width = 10
Wheel offset = +22
Tyre size = 245/40/18
Modifications to fit = Rolled front, lipped and pumped rear by 5-8mm (front not done yet but that's all it needs) + i have next to no camber with a bit it would be nice.
I would say "just fit" lol Im sure you would encounter some scrubbing. When i had my 10.5 wide on the back over 1##km/ph the rear would be pressed down on the tyre causing it to wear pretty bad.
Looks awesome though!
Where did you get the rear guards worked on?
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
