17x10 +18 would be my pick for a R33 GTR. 9" +35 is too thin and offset is too high, +18 is a bit better than standard, but if u were going to have a 17x9 id stick with stock R33 GTR rims as they are better quality than the enkeis. 17x9.5 +38 is too high offset, +18 would work, but honestly if i was going to spend the $$ id do it right first time and go 10" wide. gives u more options.
Thanks, I'm having a look around and most tyres that are 255/40/17 or 265/40/17 are a large difference in price, which would be my main reason for going for the 9.5".
However the difference between 9.5 and 10" is about 7mm more sticking out in the 10" and 1mm less clearance, so the 10" is looking more tempting, I *could* run 255/40/17 on a 10" but might be a little stretched....
But I saw this section of this thread and 255 don't look stretched on 10" rims, hmm 10" is looking good.
Skyline model = r33 gtst
Wheel diameter = 20"
Wheel width = 8.5"f 9.5"r
Wheel offset = ?
Tyre size = 225/35/20f 245/35/20r
Modifications to fit = roll guards a little.
sometimes scrubs when turning and hitting bumps together.
Skyline model = r32 gtst
Wheel diameter = 18"
Wheel width = 8.5
Wheel offset =
Tyre size = 235/40/18
Modifications = car is lower and has the big R33 front brakes
(best pic i could find to show how low it really is) (is the tires and wheels specs above)
any one had a problem with the inner side of the tire scubbing the top of third link front only?
Edited by nissans52
Skyline model = '97 R33 GTST
Wheel diameter = 17
Wheel width =8s, 9s
Wheel offset =+40 +40
Tyre size = 235/45
Modifications to fit = None
Fit good. May consider 10mm or 20mm spacers at some point after I lower it a bit. May go for a lower profile tyre also.,
Edited by Battery_backup
hey mrbenno,
can u email me at [email protected] ?
sorry im not able to send u a private message as im still new.. im interested to see how your emotions look on your gtr32, as im planning to get thjose too, same size offset and width..
thanks
Skyline model = 1989 R32 GT-R
Wheel Brand = Work Emotion XT7
Wheel width = 9.5"
Wheel offset = 20
Tyre size = 245/40/18
Modifications to fit = None.
Car is quite low, as low as a set of super low springs if you had them. ( I have Teins)
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
