Hey Braddd, this is my first post and I don't want to come in too hard straight off the cuff, so forgive me if this sounds too authoritative, but you know thats not legal right?
225/40R18's shouldn't be mounted on anything bigger than a 9" wheel.
215/40R18's shouldn't be mounted on anything bigger than a 8.5" wheel.
with that in mind have you considered;
rear: 255/35R18
front: 225/40R18 or even a 235/35R18 (a bit hard to find)
:):laugh: :laugh: :laugh: :laugh:
dear god, someone illegally modifying their skyline, we must alert the prime minister!!
is this manual what police will defect you via?
i got done on the weekend for a 235/40 on a 18x10 so now im thinking ill just stick the right size what is recommened for 10" in your book pls?
Yes... it is.
your 235/40R18 is 645mmOD
10" options
255/40R18 is 661mmOD
255/35R18 is 636mmOD
265/35R18 is 643mmOD
its all about the stretch! haha
are you sure 225/40 is legal for 9" rim? i would have thought youd be pushing it..
bradd u wont need to flare rear just roll guards and camber should look tough as! ive got 18x10 +20 and i just rolled but havent dumped it yet may need more guard modification when i drop another inch.
also nisskid what are the chances of fitting a 255 or 265 under r33 guards lots of camber im guessing?
i guess my question is, why do u want a 255/265 if ur willing to run a lot of camber? lots of potential contact path, but with a lot of camber ull end up with less contact path than a 225 with less camber.
u can get 255/265's under 33 guards easy with the right offset.
cos they almost made me get my car towed home :) so id rather go with a bigger tyre / camber and keep the po po off my back.
slightly off topic u know anything about hsd coilovers? how u rate em?
best u can do is play around with 2nd hand scraps of different sizes until u find out how big u can go, then just buy a tyre in that size.
as far as HSD's, when ur talking bottom of the line suspension they are good in comparison to other stuff of it's class, seems the BC stuff has been all the rave recently tho, and a good mate of mine reckons they are decent based off some research, so id be inclined to believe him. although tbh, i never really recommend anything that cheap for cars like ours, it's just all too low quality imo
yeh fair enough i figured they werent going to be high class but all the jap stuff is very pricey atm but i think i might just stick with teins do it right once.
thanks mate advice is spot on as always :)
nothing wrong with providing a bit of information mate... how it's used is up to the individual.
true, but u'll find generally people going outside the boundaries of whats recommended understand that. tyres very rarely pop off the bead for no reason, and it's no different with stretched tyres, ull find only the ridiculously stretched tyres ever come off simply under additional load.
yeah nisskid I know you regularly run stretched tyres and so do many people, and you probably have not had an issue.
but to me going against the actual manufacturer's recommendation, as well as ADRs so it looks drift hectic is pretty silly.
just buy wheels and tyres that fit the car properly and safely.
any time you are relying on a inward stretched sidewall and camber to tuck the wheel inside the guard it is getting pretty silly.
Wouldn't you get done for having a too wide rim anyway? like the 2in wider than standard rule.
I assume it's a gtst? so 16x7 standard.
Here's the thing,
There is another manual used called the Universal Tyre Fitment Guide which lists all OE fitments of wheels/tyres/offsets for australian delivered cars which is also used by authorities on matters such as overall tyre diameter increase & track increase etc (mainly for 4x4's). Because it only references Aus delivered vehicles, only select Skyline models are shown such as R31's and some GTR models.
Without a reference as to what an imported vehicle came with as standard it is near impossible for police to prosecute, unless however the tyre placard on the vehicle clearly states a rim width (most don't). So with this in mind, assuming you are within the recommended outer tyre diameter as per your local authority and the tyre is mounted on the rim as per the Tyre & Rim standards manual you 'should' be fine.
Every state authority is different though, it's up to the individual to do his/her due diligence.
police in tassie are totally oblivious to this shit, get defected for totally bald tires and thats about it, maybe if you zorst is too loud...
:D:D:):laugh::laugh:
LAAAAAAAAAAAWWWWWWWWLLL
Edited by Braddd
each to their own, there are reasons why manufacturers only recommend around 3 sizes for 1 wheel size, mainly because there is no reason to do otherwise. 3 sizes is a big enough window, and there is absolutely no reason for tyre manufacturers to widen the window, as low as the risk may be.
and ADR's are simply based off manufacturers recommendation, they carry zero merit on their own.
and for the record, everyone does things to their cars every day to make them look and sound better that make their cars illegal, wheel fitment is no different, it's just some dont get it, but that's the beauty of styling, everyone has different taste. some times u just have to accept that you dont like the styling, but many others do, just like you may like the styling of ur car, but many others dont.
also for the record, although this is kind of off-topic in this situation, stretch can be used to firm up the sidewall of tyres that dont have the reinforcement that high end performance tyres do. a good example is im currently supplied neuton tyres from my sponsor to drift on, now they are a cheap tyre, and yes ideally i'd like to run high end tyres, but when ur chewing through a pair every few sessions then it's just not ecconomically viable at my level, so what i will be doing is getting rid of my 17x9's on the rear in chase of some 17x10's, but keep the same 235/45 tyre, this will stretch the tyre more and give me more feel, yes the unsprung weight will go up, but with the added feel, and minimised deformation of the soft sidewalls, it's worth it.
just to correct here, standard gts-t is 16x6.5 (+40 if relevant), so even less lee-way.
also even if he doesnt get done for too wide, they will do him for protruding tyre, if a officer can look down the guard from directly above, and see tyre tread, then apparently it's illegal, or at least in police's eyes. the biggest issue with this is police struggle to grasp the difference between tread, sidewall, and rim.
That's not 100% correct.
Whilst Australian Standards are developed in conjunction with manufacturers (along with engineers, industry professionals and international associations) they are not based on manufacturers recommendations solely and at times a manufacturers recommendation is at-odds with the Association standard. In such cases the Association Standard overides any manufacturers recommendation.
An example:
Mickey Thompson MTZ 285/75R16 - According to the manufacturer it may be mounted on a 7" rim
Australian Standard says minimum for a 285/75R16 is 7.5".
In this case the Australian standard overides the manufacturers recommendation.
Apologies for getting all technical.... and sorry for using a 4x4 tyre as an example, it's just something that came up the other day and was fresh in my mind.
Edited by thewheeldeal.com.au
fair enough, so engineers in Aus have tested every single tyre size on every single wheel combination to determine what's safe and what's not?
Safe or not mate, it's the rules... I didn't write them, if you have an issue with them then take it up with the Tyre & Rim Association of Australia.
no you just said that they weren't based off manufacturers, which made me think it was based off their own tests, that would mean they would have to test it all themselves and engineer every single possible combination. if not, then afaik my statement still stands that they carry no merit of their own, they are just guidelines based of standards given by other sources.
i think people should look at what the evidence is before making their decisions, if people really want to stretch, then they can look at the others that drive/drift/race on stretched tyres and they can make their decision based off that, i have, and i am yet to find a case of a tyre popping off the bead with mild stretch besides crashing or hitting something, therefore i made the educated decision that stretching was fine. if people arent willing to take the "risk" themselves then good for them, but expect to be greeted with opposition if you suggest it's unsafe without any real evidence.
FFS, wheeldeal.com/whateverthef**k, its the job of the police to enforce the law, thank you for sharing the laws however i think you may find that the people on this forum put certain rim and tyre sizes on their cars because they WANT to, in order to achieve a certain look. and in doing so are prepared to deal with the police attention and such. so i dont think they care. myself included.
also bitchin like this makes the site seem like boostcruising.com and bloody nobody wants to end up like that joker of a forum...
Edited by Braddd
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
