bit sunken cant see any issues
Cool, have rims that need heaps of camber to stay inside now & with the popo getting a bit firmer up here I would rather not stir the pot so to speak. Am looking at LMGT4's with track rubber on em, & +30's is what seems the goods to me
what you got on now ill tell you exactly how it will sit/look.
Got 17x8+32 on front-sits good, 17x9 +36 on arse & rim sticks out by 3-4mm-Drifteks cause I think they suit the shape of the body best-my view only(based off picks of LMGT4's anyhow), want a lightweight wheel now-am starting to track it
front will 8.5+30 would sit out 8mm more than your current setup with 4mm less inner clearance
rear is exactly same outer position but you have 12mm more inner clearance 9+36 or 8.5+30
have you rolled your guards or anything? maybe try that and straigten up the camber a bit
yep guards rolled out, cheers mate-think I have found just what I am after
Wanted a recommendation for R32 GTS 4, want identical front and back in 17 inch, I was thinking of 225/50/17. Is this too high profile? Would 225/45/17 or 215 something 17 be better. Strict street use. Aiming for total legal. Thanks.
no get same sizes all round.
will look pox.
also bad if the rolling diameter of the wheels isnt the same with matching tyres
gtr's really need the same all round, otherwise bye bye attessa
Was looking at getting some Work XD9 for my 33 gts-t- Blags has given me some good info.
Car will do 1 or 2 track days per year, would prefer not to run stretched tyres. Will roll the guards.
Looking at 9 +20 fronts and 10 + 18 rears. Will a 225/40 or 235/40 front and 245/40 rear tyre fit ? I am guessing a 265/35 may not fit on the rear ?
thanks
whats the rim width thats kinda of important. im guessing like 7inch?
Haven't bought rims, so I want opinions on the best width and offset. I want same all round. No upset to ATESSA.
you don't have ATTESA lol
LOL I don't have a GTT, joined forum aspiring to one, couldn't get a loan for one (thank god!), paid cash for an R32 GTS4, does have ATESSA, back to the topic wanted to know ideal 17 inch rim tyre combo for stock guards.
thanks
if your doing track days i guess you dont want camber, i did fit 265/35 on 10"+20 with lots of camber.
the tyres sizes you are suggesting are "Stretched" as they are not the recommended tyre sizes for the rims your suggesting. but without stretching tyres you'll struggle to make them fit gts-t guards.
Skyline model = r34 gtt
Wheel diameter = 19inches
Wheel width = 8 front 9 rear
Wheel offset = +23 front +9 rear
Tyre size =215 front and 225 rear
Modifications to fit = everything lol, flare, roll, pump, remove inner plastics.
next set of rims will be even more ridiculous probs go bolt on flares
GOT SOME NEW RIMS NOW
18x9.5 +15 te37s
rears will fit sweet (i think perfectly flush)
fronts will stick out about an inch i think so gonna dial in some camber and some stretch and see where we go from there hahaha
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
