Dont run staggered setup on GTR...and get the 10s +22 with a 265 tire. Should all sit in nicely front and back. Sorted.
Have a look back at my pics of 32 GTR, they are 10s all round +11R and +12F with 265s all round. Yours will sit in a full cm in comparison.
It's rolling diameter of tyres that have to be within 2-4% (can't remember exact percentage) otherwise ATTESSA stuffs up.
Width and offsets aren't the issue, a friend told me about a 34 GTR had 4wd issues and mechanic lined all 4 wheels and noticed 4 tyres are different (all are purchased brand new in same size all round), that was enough to stuff the 4wd up.
ah yeah, iv heard of that with the ATTESSA. Not about width differences tho. Having said that it is easy to changing said rolling diameters by unknown quantities as as 225/35/18 is not going ot have the same rolling diameter as a 275/35/18 right?....
does anyone know if 19x10 +20 will sit flush with r33 gtr guards?
It'll fit easily providing you low it.
also what size spacer to make r34 gtr wheels it sit flush with r33 gtr guards?
25-30mm spacers + low will have this wheels fit flush in 33 GTR.
Thanks
yeh wont fit that under stock front guards without stretch/camber/guard bashing.
i think its important that people dont just say "it'll fit fine" unless it actually will.
fitting and been made to fit are not the same. :thumbsup:
im considering putting 18x9+15 F and 18x9.5+22 R on my standard guard 33
any advice?
Seems like a pretty nice fit to look aggressive on standard guards
will need front guard liners removed, all 4 guards rolled, and 225/40/18 fr 235/40/18 r
guards may need a lil pull, depending on height
depeneding on how much camber you are running and how low you are id say you will still be able to get 255's on those in the rear...
iv got 18x9.5 +36 with 275's. As little camber as the standard arms offer + pretty low n there is heaps of room. only just needing to roll the guards...
you can put better 235's on there.
a high quality 235 will give more grip than a cheap 265
agreed. I think alot of people make this mistake.
But a sticky & fat tyre... :)
that is my new 275/35/18 Toyo Proxes4 on a 9.5" rim (+36). Minimum camber and lowered a fair bit (bodykit is 14mm at lowest points on the front lip and side skirts).
See heaps of room left in the guards but sitting pretty flush
Edited by jjman
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
