hi i have a 1993 r33 gtst at stock height i have stock rims atm but want to change i dont want to have to do any mods i am looking a 18s what width rim should i go front and bak tyre size and offset if you have any information i would like to know thanks even 19s need to be able to slip straight on
what about my other post do you have any idea ? on what are the best size 18 or 19 in width and the off set i will need to slip them straight on if i went 18x8 front and 18x 9 rear with +38 will that be fine nd will that be fine in 19 also ? and what rims do people recommend i dont want to break the bank though
Edited by khyle
Looking at the new Advan RG-D wheels,
http://www.advanwheels.com.au/wheels/wheel.aspx?id=23
The only option that appeals is the 18 x 10.5 which comes in either +15 or +25 and i would run 265/35 tyres.
Wondering if anyone is running any of these sizes on a R32 GTR ? and what sort of clearance issues i could expect other than just having to roll gaurds.
Cheers
Based on how mine fit up, I'd say you'd be best with the 10.5s +25...would sit very similar to mine...the +15s in that width would be a struggle! They'd be out another 10mm or so compared to mine...check pics a page or so back...I'm running 265s as well.
Edited by NSNPWR
Hey mate,
Im looking at exactly the same wheels for my 1993 gts.
Thinking of getting 18x8.5 all round, not sure of an offset tho.
Did you have to roll the front guards or only the rear? Also do u rekon theyl fit? lol
Thanks
:thumbsup: exactly
Hey mate,
Thanks
Wheel: Lenso/Raiden D1R (Project D)
Skyline model = 1994 R33 GTST
Wheel diameter = 18"
Wheel width = 8.5" Front, 9.0" rear
Wheel offset = +35 Front, +32 Rear
Tyre size = 245/40ZR18 Front 265/35ZR18 Rear
Modifications to fit = Roll Guards
Want to correct the camber a bit so may need to do something with the guards if I do that
Hey guys. I'm pretty new to this website so forgive my noobyness. I'm not really understanding the whole offset thing.
Anyway ive got an 1993 r33 gts (non turbo) 4 stud an looking at fitting lenso d1r 18x8.5+35 to the front an rear. Only mods are lowered springs.
Would they fit without any guard trimming/rolling and without any rubbing on front wheel arch/steering rack etc.
Just want a nice rim that will sit flush.
Any help would be much appreciated. :)
does anyone have any idea how to order work wheels using the nengun website?
i tried but i can't figure out how to choose the offsets and width.
so far, i have standard brakes/calipers and 17" factory rims.
i want high buff 18" work wheels S1 2P to suit the standard brakes, etc
here's the web link i tried using http://www.nengun.com/work-wheels/meister-s1-2-piece
if anyone could help me out, i'd appreciate it
Soem tips:
Ask them to check availability before you send them any money.
You cant decide what size/offset to use or you cant get the website to reflect what you want?
the thing is, i don't know what offset to use when selecting the wheels. i want something with standard brake caliper clearance, deep dish, 18", no rolling of guards,no tyres that stick out of arches, and no removing of wheel lining.
basically something that fits without modification.
these are the specs i tried plugging in nengun.
offset: 35
width: 8.5jj
18" high buff
then it gives my a box labelled "A". what do i put in that box?
is the price they quote on the site per wheel of for a set of four?
so damn confusing.:/
this is how mine sat...work equips 18x10+18 265/35 all around with offset bushes front maxxed, rolled guards, camber arms maxxed rear :whistling:
last 2 pics are with g4 coilovers...which i took out after a lap around the block...
Edited by roadworia
haha gotta pay top dollar for top quality !!
have a look at the work emotion series, still good quality & a fair bit cheaper than meisters.
just got myself a set of 18" XD9's which go on tomorrow ! :D
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
