Just wondering if 18x10 +15 with 225 tyres will fit on the rear of a gtst with only little lowering with coil overs no camber arms
Cheers
Chi
i tried a 18x10 +12 not long ago. with a 225 and a little more camber it could be done. at the time mine was set at -3 degrees. id say with some guard love it 'could' be done
Hey guys, I'm going to be completely honest here. I don't know shit about offsets... So I need to ask you guys this question.
I have an R33 1993 GTS-T and I want to fill my guards... I want at least 235 on the front and 255/265 on the rear on an 18 inch rim. What offsets would make that fit without spacers and make it fill the guards? I don't mind if I have to roll them either.
i got away with 30offset 9.5 all round, but the front is tad too much in my opinion, better with more on front so you can turn the wheel and not scrub. The inside of the rim is scrubbing the strut on a full lock so ill need spacers..
hi,
after reading through this posts, i'm considering getting a set of rim - 245wide rubber with 18x8.5" 25mm offset front , and 285wide with 18x9.5" 29mm offset. I have R33GTS and sitting about 345mm from center to the guard. Can someone please confirm this is possible without guard work?
Thanks
got an r33, have coilovers,
getting a set of work vsxx rims orr Mr Eps (oooh namedrop)
17x8 +40 F
17x9 +40 R
i'm thinking of 15mm spacers all 'round?
i just want them sitting flush, maybe sitting out a little.
would i need my guards rolled?
what is a good offset for a r33?
might not be the right place but i figure you guys would know, where can i get quality spacers?
hi,
Thanks
you'll need guard work for sure,
both front and rear? rolling guard or have to flare?
Also if i'm going with +40 offset for 8.5" Front & 9.5 Rear, would it help and not touching the coil over?
Thanks
40offset is very conservative, no problem with that offset, those specs done easy
could go 9.5 on back with 30offset, that be filing up arch, front id say 9inch with 30 offset, will need rolling on back and front still id say,
the front becomes an issue when you want to go up a driveway and the wheel has to turn and come up into the wheel arch, full lock hits the strut.
depends what your after really
SliverS2:
in your opinion which is better setting where minimal or no body work in the options i have available? note that the car is sitting 345mm from center to arch so that it's not low, about 25-30mm lower than stock height.
available option 1. Front 8.5" 25 offset with 235wide rubber, Rear 9.5" 30 offset with 275-285 wide rubber - rolling guard to F & R needed? hits strut?
available option 2. Front 8.5" 40 offset 235wide rubber, Rear 9.5" 40 offset 275-285wide rubber - rolling guard not needed? hits strut?
available option 3. Front 8.5" 30 offset 235wide rubber, Rear 9.5" 38 offset 275-285wide rubber - rolling guard not needed? hits strut?
Thanks for your help.
SliverS2:
this is a tuff question, all i can do is go off whats on mine which is the 18 by 9.5 with 30offset all round
Ive just measured mine and ive got 323mm at the rear and 329mm at front, that the distance from center to the arch.. so mines bout 15mm lower and i have very firm tein coilovers
Id really recommend rolling your arches , its bout $50 an arch and then theres less hit and miss with all the options you've gave, atleast on the front because when you try and get up driveways and odd angled entrances etc, on a steering lock your wheel arch might dig into the tyres.
On the front , 40 offset is safe, 30 offset should be fine, and 25 offset borderline, should all clear the strut ( assuming you dont have rolled arch and the suspension a bit soft and a tight steering lock going up a driveway) if you roll the arches , all are fine
On the back, 30 offset you'll have to stick with 245, might get away with no rolling wont hit strut
38 and 40 offsets you'd go 255 , with rolling 265? shouldnt hit strut
Hope that helps a little, on my car the rim is about inline with the arches so i think its about the limit of offset, but others might say otherwise.
feel free to correct me if im wrong anyone...
yeah i will roll them!
between i have super street tein coilover, not overly firm but firm enough.
look like i will go front 8.5" 30 offset with 235 to give it more aggressive look. Rear 38/40 offset with 275/285 to give me more traction.
Currently i'm running 8.5" rear with 255 federal rsr and is very close to flush with the guard. Just had a look, it seems like about an inch on the inside.
do you think 275/285 is possible?
i think 275 is more GTR tyre width, pushing it i think,
so if its flush now with 8.5 rear , it'll come out another 12.5mm so even the 255 will be close.
17x8 +40 F
17x9 +40 R
dont buy them and dont run spacers they are shit specs.
orly?
SliverS2:
best combo to fill ur guards and look 'ok' is 8.5+25 and 9.5+30 you can run much smaller tyres that will fit just fine with minimal stretch a 235 fits a 9.5 easy
its also worth noting depends how low you sit/want to sit.
wtf u need a 275/285 tyre for? unless you have 800killerwasps thats overkill
i want 275/285 to give more traction. as mentioned i'm running 255 fed rsr. used to have 280 rwkw and the 255 was fine with 2nd gear... but since upgrade the turbo i have problem with traction, in 3rd gear i have no traction until it really warm up and which just give a bit of chirp. hence only go wider rim for more rubber. :thumbsup:
orly?
whats that mean?
the wheel arch is not quite big enough to allow that width, you'd have to have the guards modified, 255ish is about the limit, maybe 265 with a good roll and pulling on the arch, and that would be with a 40offset not a 30, so it wont fill the guards as much as the 30offset with 245, 255 possibly??
i had 18x10+20 on the rear with a 265/35, rolled guards and cambered of course. Wouldnt do it again though hate big tyres.
that would of came out alot hey.. i cant imagine getting much traction with more camber than the standard,
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
