Skyline model = R32 GTR
Wheel diameter = 18"
Wheel width =10"
Wheel offset = +15 (Rota Grid)
Tyre size =265/18/35 (appropriate stretch
Modifications to fit = nothing (car is lowered practically on coilovers.
finally lowered my car these pictures are for alex although i wanted to go lower in the rear its currently maxed out stupid BCs!
Specs are as followed
18x10 +10 225/40 rolled front guards
18x10.5 -9 235/40 flared rear guards
Wheel width =10"
can we see :)
how are you guys going with a full lock on the front wheels, cause i have 18*9.5 all round 30offset and the front wheels are hitting the struts, has already shaved a bit off the strut..
thats on a r33.
Edited by SliverS2
Anyone know if 18x10 +20 will fit under an r32 GTR without major modifications?
It already has rolled guards.
Cheers
i would say they should fit, but it will also depending on tyre size and how low it sits...
Should fit easily, a bloke few posts up have 18x10 +15 which is sticking out a bit - without rolling guards.
Yours will tuck in a bit, nothing to worry as you've rolled the guards.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
